I’m trying to install the Xlab carbon sonic wing on my 2013 cervelo p2 seat post but it looks like the wing is off by 0.5mm and not lining up correctly with the seatpost? The screws will fit through one side but the other side won’t line up no matter how I position it. Am I doing something wrong? Has anyone had this problem?
It seems like it is off. Maybe I am being too gentle? I don’t want to break it though. You think I should file the hole down to create a bit more room for the screw?
You could file it a little it won’t hurt anything. Be gentle. Carbon can be brittle. Try putting the bolts in from the other side. Maybe one plate is slightly different. A tight fit once fully installed will be ideal.
Thanks Damon. I received your email. I was able to use a drill press to make the top hole just a tad bit larger and it fit like a glove. Thanks for your help.
Cheers!
