XC question-transitions
My son is racing a pursuit next weekend-coupe de France-7.5K mass start classic followed by 7.5K skate. As triathletes we realize the importance of fast transitions. So here are the options:
  1. choose 1 set of poles depending on the course profile
  2. change poles
  3. buy the TOKO straps (112 euros) which on must undo and put on the other pole
  4. are there any other options?
Which to you prefer and recommend? Thanks for the input.
This will truly be an endurance lovers course as they will be doing a 10K the day before this pursuit. This is a lot of work for a 16 year old but I think it will separate the fast twitch from the ---------- :wink:
bump
It would really depend on the course profile. If it is relatively flat, without any serious climbs, it might be possible to double pole most of the way. If that’s the case, using one set of poles (the skating poles) may be the best option.
HOWEVER, changing poles does not take that much time. I would recommend switching in the transition. The thought of DPing the first leg (for 7.5k) would probably take its toll on the second leg. Even if the course has a flat profile, I would switch poles. I’ve only done a few of these and I’ve switched poles each time.
There are others on this site more qualified, but I would spend the few extra seconds and switch. Good luck to him!!
thanks, so far it seems to work best with the pole change. there is a protetype (sp) that is being used where the straps stay on the hands and you clip into the pole. he seems more comfortable with a change and comfort=efficiency in this case anyway.
