Hi
Have an X Lab Torpedo, a great product! Very happy with it
The only problem is how do I stop the splash from the refill hole?
Am using the refillable lid as supplied and realise that they will be some splash but was wondering if anyone has any Soloutions to help at least to reduce the splash
Jonboy
Had the same issue, I switched to the solid lid and had no issues with that.
It has a loop that goes round the straw so it wont fall off whilest riding and is easy enough to open and close.
I use the solid lid as well and don’t have any issues. With the slotted lid, I wonder if the sponge that Profile uses in their aero bottles would help you. I believe you can buy these as an aftermarket product.
I’m sure I’ve seen those on their own.
I kind of like the solid one, you can see how much is left.
I also use the solid lid.
Ditto to using the solid lid. It’s easy to open and fill, so there is no need to use the mesh lid. I also tape over plug in the extra straw hole so the plug does not come out.
just get a loofah for a dollar and cut it to size.
As others have said, if you don’t need the open slot, the solid lid is very easy to use with no splash back.
Plug shouldn’t pop out on its own….email me a picture of the one you have and I will see if its the latest version.
