WTB: XLAB Torpedo
Need an XLAB Torpedo mount and cage if you have either one or both. Let me know what you have and how much you want shipped to 64016.
Thanks!
I believe mine is available but will check when I get home. You will need your own nut and bolts for the cage to mount. The ones that came with it oxidized very quickly.
I’m sure it will fit in a small flat rate box, so $20 shipped
This is the one that goes on the aerobars correct? You are talking about the bolts that holds the water bottle cage to the mount?
Thanks
connect
Is it the carbon model? Last question, I promise. :slight_smile:
Yes, I don’t believe they make any other model
I’ll take it. Bracket and cage. Pm me the info and will paypal tonight.
There’s no cage
Can I get a quick pick? I guess I’m just confused about the nuts and bolts. Didn’t know it require those unless you are talking the ones that come with the cage?
pm me your email address and I’ll get you a pic.
Basically the set up is a carbon plate with some straps. The carbon plate has holes that you mount a cage to with small nuts and bolts. The ones that came with it are missing, they oxidized very fast.
