BBright specific? I have standard or aerp
I thought 3D was 24mm and 3D+ was the 30mm?
I just need the arms and spindle for my p2m. Can you send pics and prices to s.gentz@live.com. Thanks
I have 3d+ aero and non-aero spindle… Emailing you.
You are right that 3d is 24mm but the 3df is 30mm.
I would prefer the 30mm.
If I recall correctly, the 3DF and 3D+ have slight differences to their mounts - so please check with power2max if your spider can fit both spiders before spending the money…
On the p2m site they say it will work with 3d 3df and3dplus. Thanks for the heads up though.
The p2m 3D are totally a different interface from the 3Dplus. Your p2m will have the exact model etched on the spider. If you are unsure then email p2m as they will be able to tell you what is compatible, as there are different Rotor interfaces - and only one will fit. Their customer service is excellent, and you can also buy crank arms separately from them (I have done this through the European site as I am in the uk)
You are correct. I have the one that works with 3df and 3dplus. I think I may have actually found a plus from an st’r. Thanks.
