Wtb: m2racer power module
anyone has one of these for sale?
Just a rant about the power module… if you’re using to to try to get steep on your bike (as opposed to wanting something that’s adjustable on the fly), you’re better of with another solution. I used it with a pretty typical saddle, but mounted it all the way forward on the power module, and the rails of the power module ended up bending on me. I was riding a Giant TCR Aero frame (which is pretty much a road frame), and it wasn’t steep enough.
My final solution (before I switched to a cervelo P3) was to get a profile design tri stryke saddle, with its nice long rails. Put in it’s most forward position on my seatpost without the power module, it worked perfectly (must have given me about 78 degrees, with it all the way forward and me perched on the tip of the nose).
Hi thanks for your input!
Would I be able to get further forward if I used a fizik arione tri, or a profile design tri stryke?
The arione tri is slightly longer than the tri stryke, but I think the rail design plays a part too.
Any ideas?
Thanks!
Interestingly enough, I used both. (= You’d get further on the profile design tri stryke, and personally, I found it to be more comfortable. Yes, the arione tri is longer, but the rails go further back on the tri stryke.
I had one which the rails snapped. I liked it, but they needed to make it more durable.
Stephen J
I had one, too, but the rails were not parallel and it was very hard to get the seat rails to mount properly into it. Not very well made.
Agreed. This was some of the worst money I ever spent. The seat-rails never fit! I would sell you mine but I don’t think you’d be very happy with me.
