Does anyone have a 2006-2008 Mavic Ksyrium Elite rear wheel hub?
Mine is now cracked, my bike shop does not have a replacement, nor does Mavic. So, I am reaching out to you all.
have you disassembled the wheel already? i ask because the nipples and spokes on the older ksyriums often get fused together (alum on steel)… and so you’d end up having to replace a lot of the spokes and nipples + the hub… just to save the rim.
Hmm, never thought of that. I was just told that my hub was cracked and since they could not replace the hub, I would reach out.
That is a good point. If anyone has a rear wheel black, please let me know.
I have a Cosmic rear hub laying around. Would that work?
I have a 2006 Ksyrium Equipe rear hub if that helps. Not sure if it is the same as the elite, but let me know if you think you can use it.
I have a ksyrium sl ssc set for sale if you want the whole wheel. Would have to be both together though. Good luck
I have an elite hub if you need it.
