This may be a long shot, but maybe someone here has a front disc wheel? I’m looking to use it on the track. Clincher is fine, tubular is preferred, 700c is mandatory. I know that a wheel cover is the cheaper, easier way to go, but certain events disallow those covers. Please let me know if you have one you would like to sell. Thanks!
i saw one on ebay recently maybe it is still there.
plus those wheel covers are designed for dished rear wheels
Well, I didn’t find one on eBay, though they do crop up now and again. The signal to noise ratio of a ‘disc wheel’ search is really low since the market is saturated with mountain bike parts. If you find something, please do send it along!
Thanks for the tip on the dishing of the usual wheelbuilder covers. I’d be apt to simply find a sheet of thin polycarbonate and fabricate one myself. For most events that would be fine. Silly UCI and its rules…
Specialized/Hed trispoke + sheet of carbon fiber/fiberglass = UCI legal front disc. I trashed a trispoke in an accident on the track and I plan on reusing it for a front disc for individual pursuits and kilos for next year. Granted, mine will have to be structural as i’ve ripped out part of the carbon, but yours can just be a nonstructural laminate. It would probably be much cheaper than a front disc and possibly more aero as well. My Zipp 950 is around 21/22mm wide whereas a trispoke is 19mm wide. If you want to do some extra work, you can bond 3 smaller pieces per side inside the voids and then smooth it out rather than gluing a giant circle of the laminate around the whole wheel which would add probably a millimeter to each side. You’ll probably want to glue a roughly shaped piece of foam in each of the 3 voids to give it some extra puncture/impact protection and stiffness so it doesn’t crack if you lean it up against something or something lays on it in your car. If you were really concerned about someone questioning your wheel (which they shouldn’t, as it would be a ‘structural’ bond and no one should even know what is underneath) you could always slap some Zipp of Mavic stickers on there.
You might also want to look on the FixedGearFever forum as well. It’s an actual track racing forum, not a hipster forum, and high end wheels pop up quite often. Mavic Io’s are probably the most common front wheel that pop up, but I’m sure you can find a front disc if you don’t have any particular rush.
You can filter ebay for road bike parts only.
Styrrell
Yes, I’ve seen the trispoke-to-disc conversion at http://forum.slowtwitch.com/...um.cgi?post=2165924. It’s very cool, and something I’ve considered. I could easily badge it as a HED wheel since, at one point, HED did market the trispoke disc. Fixedgearfever is a good resource that I’ve forgotten about; it’s been too long since I raced on the banks as seriously as I should. (It’s ironic to be talking about track on a slowtwitch forum!)
Filtering on eBay helps, but the SNR is still low, and I’ve found some of my best eBay deals as miscategorized items.
I’ll keep looking - thank you for your responses thusfar!
One of my friends has a front disc, I’ll ask him.
