Reading up on HED wheels, it seems to me you’d be hard pressed to justify the Stinger Disc over the Stinger 9 as a rear wheel.
Read their explanation, expecially the percentages… http://www.hedcycling.com/wheels/
The Stinger 9 wins up to 7.5 degrees, then it is close win both getting their nose in front here and there up to 15 degrees before the disc starts to be significantly better.
So , the questions are posed:
At winds that cause a yaw of 15 degrees or more would most people even be riding a disc?
Given the benefits of weight and aero advantages up to 7.5 degrees is the Stinger 9 a better choice?
Look at the links again, and how fast do you ride and how windy is it typically? The example they give is only with an 8 mph wind and I think most people who would consider a disc would ride it in that wind. For their 26 and 20 mph rider examples, they will see apparent wind angles of 15 degrees or more 26% and 58% of the time, respectively. Even for a fast rider, that’s a lot of time in the zone where the the disc offers a huge advantage. At it’s worst (15 degrees), compared to the S9, the disc gives up about 5 watts and I believe that’s at 30mph so at mortal human speeds the drag difference would be less. By 17.5 degrees, the disc offers more on the order of 10ish watts saved. I suppose if you determine that the combination of wind speed and angle and rider speed for a given day puts you in the 13 to 15 degree apparent wind range, the S9 would be the superior wheel, but it’s the difference between great and really great. If the conditions put you in the lower wind angles, I’d call it a dead heat as neither wheel greatly outperforms the other.
I remember reading (here?) that the discs were tested with a cassette on, while the spoked wheels were front wheels. If this is true then that could explain why the discs aren’t really better than the deep dish wheels.
Hey thanks QRNub, how did you get the wattage differences? On the site they talk in grams of drag? How does that transfer to watts and how does whats then transfer to speed (on the flat for example).
Cause this is the crux of my issue, I will never be using the rear wheel on a course where the hills negate it’s use. So I’m trying to work out which is the most versatile wheel depending winds.
I tend to average around 40km/h so spend a lot of time on flat at speeds greater then this.
I only ride courses between 20 and 45km in length.
It’s something like 9 grams of drag=1 watt. You can’t directly convert watts to speed as the faster you go, the more watts it takes to go faster. In other words, if a rider wants to increase from 30kph to 31kph it will take fewer additional watts than it would take the same rider to increase from 40kph to 41kph. Power is a function of velocity (approximately) cubed.
One question begging to be asked: are you sure you want to ride tubular tires? I’m not suggesting you should or shouldn’t, just asking for a variety of reasons such as performance, cost when/if you puncture, and ease of use. According to Hed’s info, the Stingers are great aero wheels, but that’s only part of the story that we all have to balance for our own “real world.” Different wheels offer different ride quality, lateral stiffness, etc. I’m definitely not knocking the Stingers, I haven’t ridden them, I’m just saying there’s more to the decision than the drag chart.
Hopefully, some others with more experience with various configurations will chime in once the sun comes up. Hed (specifically Andy who posts here occasionally) has a great reputation for customer support with decision making. Have your specifics worked out (you pretty much do: speed, terrain, typical winds, are you on a “funky” frame like a P3/4 or Transition) and give them a call or drop them an e-mail.
Not sure on bike yet, it will either be a P2C dedicated time trial or Soloist (S whatever?) with clip on aero bars.
Haven’t decided that point yet cause I can get a good aero position on both…
Anyway, it seems the biggest difference between the two is 13 to 15 watts. That is considerable, but given the disadvantages such as weight, slower at lower yaw’s etc???
As has been pointed out, quite possibly the Stinger 9 was a front wheel without cassette…
Decisions decisions…
I tend to think the disc is always faster, at least that’s what I’ve been brought up on… but who knows and once it is actually on a bike both wheels might behave differently, doesn’t a disc help smooth out turbulence created by seat post, legs, etc…??
The question you wish to address is: which rear wheel would produce better results when I race my bike?. The answer is somewhere between, I don’t know and depends. The data we use to try to get at such questions provides some insight but not specific answers. The people at HED don’t test Stinger 9’s and Stinger discs in the rear wheel position of a TT bike (not to mention testing wheels with riders on bikes). They test wheels in isolated forks at various wind angles and speeds. While, the drag data they find may help us a bit with front wheel choices, I am not sure this can be applied to the very different situation of the rear wheel. The leading edge of the rear wheel deals with the screwed up air from the rider/leading combination. How different wheels would perform in this situation is unclear to me, given such data as HED’s alone. There may even be differences in rear wheels with different bike (cervelo versus Look).
Just get the Stinger disc and call it a day. I have the Stinger 9 front and Stinger disc and they are outstanding wheels. They handle great, are almost as light as their Zipp counterparts, probably as aero (although who really knows), cost tons less than the Zipps. I have the new Vittoria 320tpi tubulars on the Stingers and they are much more comfortable than the Jet 90 and Jet disc I used last year with the Bontrager Pro tires. They also will work on a P3/P2.
Well you are in the right part of the world! I am currently living in Okinawa, but the picture was from this year’s Ironman Japan on Goto Island. A wonderful race, but a very challenging bike and run course.
If you think you’ve just about gotten things figured out…take a look at Zipp’s site, tons of info there too. This is one fun feature: http://www.zipp.com/speedshop/customselect.php You get to select front and rear wheels and see what the time savings should be in theory. Note: the info for the 202 as a rear wheel is wrong, it is clearly the info from the 808. Also, they list the the calculated time advantage as the same for each wheel front and rear, the benefit in the rear is less in reality. There’s also a feature in speedshop that suggests good and best combinations for certain courses in various wind conditions. It’ll give you some ideas for types of terrain and how technical the routes are.
This little ditty: http://www.zipp.com/_media/pdfs/technology/rimshape.pdf is a pretty good explanation in layman’s terms what countless hours of engineering in a wind tunnel produces. It also discusses side forces which is the potential downside the deepest wheels in windy conditions.
Assume for a minute that the wheel makers’ claims are absolutely accurate. They claim somewhere in the area of 2 to 2.5(ish) minutes saved, depending on the particular wheels, compared to a 32 spoke box rim. Zipp claims a 60 sec advantage from a 303, 71 sec for a 404, 81 sec for an 808, and 90 second for a 1080. Does that matter? Yes, 10 to 30 seconds can be huge in a time trial if you’re at the pointy end of competitors. For those of us clogging up the back of the pack, it’s largely a question of disposable income. If you can afford mulitple wheels, go for it and select according to the day’s conditions. If you can only afford one, pick something that performs well in any condition and know that you’re really not giving up a great deal to the “ideal” wheel for the day.
All the info is great fun to research, I do far too much when I should be training more.
Since you’re new, I’ll get this out of the way. Weight basically doesn’t matter. Add some weight to improve aerodynamics, aero trumps weight. Yes, if you add a lot of weight and go to a very hilly course, the weight would become a detriment. In most cases, we’re not talking about a lot of weight and most of us aren’t time trialling up steep mountain grades. Now, where’s jackmott with his disc cover comments?
These are very valuable and useful informations about why to buy a set of carbon wheels.
But the question is how … or which set to purchase.
Most of us can’t afford to purchase a pair of each, go to the race spot, and according to the weather, choose the right/perfect (?) wheelset.
Even pro’s don’t do that.
We sell and distribute carbon wheels, and honestly, I’m using 3 wheels :
Front : 60 mm deep full carbon clincher
Rear : 90 mm deep full carbon clincher and a disc (tubular)
That’s all I have and I’m ok with it. I’m a decent rider (average 34 kph) on 1/2 IM or IM and never had to complain about my choice.
Now, what you must consider, beyond the aero aspect is 1. the weight, 2. the rigidity.
If the course is hilly, choose for lower profile (max 60 mm).
I like also 40 mm and 60 mm for their low weight which are so decisive for short races at the turns when you must accelerate and catch the guys up.
Also important aspect for you guys. Just use your carbon wheels, every times … you must get used to them, even for training, not only for race.
I use mine all the time (for that reason I have the clincher version)
Through all the years with carbon wheels, I see pro’s … and they love a mix of 60/90 mm profile, and some specific races a disc.
Another recommendation when you choose the wheels : the spokes !
I’m from Belgium, and I really don’t like to talk bad about belgian products, but the Sapim sucks !!! Even the CX Race …
We had so many problems with them. We change Sapim for DT Swiss.
