Worth the cash?
I’m willing. But I was almost fooled into a bad bike deal before ST saved me. 300 for a used HED disc… If it is worth it, please don’t steal this from me, ST!
I’m not super worried about looking cool or even looking modern. I just want to go fast and have enough cash leftover to pay for races.
http://chicago.craigslist.org/nwc/bik/2609851882.html
This is his reply to my question about age and braking surface:
‘I think I bought it new in 2007-2008 braking surface is aluminum and is fine, I used the brakes as little as possible in TT’s : )’
His use of emoticons makes me a bit suspicious… $300 for a disc sounds pretty appealing. If you’re super concerned about budget, a wheelbuilder cover is 1/3 the cost of that guy’s item and allows for pretty similar aerodynamic gains. But, if you don’t have a PTap wheel or really a wheel set you’d like to keep on the bike, I’d try to see the disc in person, verify the age/trueness/etc, offer a bit lower, and see what you can work out!
Brandon
I have a pre-Jet disc from HED. I paid a similar cost. I don’t regret it. If you are concerned about the year it was made — just look in the rim track— there will be an engraved number on it (for example mine says 1104-005). I believe the first four numbers are the month and year of manufacture.
And is the second number the run out number?
Or depending upon which wheel you mate the cover to, you can actually gain 1-3w over some “real” discs.
Of course depending on which wheel you can lose those a couple of watts. Back to the actual question, it doesn’t strike me as a scam. Its not particularly new, not one of the sexiest wheels around. 300 seems lowish, but theres times I’ve just wanted to get rid of stuff I’m not using will take a bit less than ebay prices just to avoid ebay hassles.
Styrrell
Meh. Heavy and comparable aerodynamics to a wheel cover, which is $100. That’s what I bought.
thats not too bad of a deal…if you are close by, check it out…doesnt hurt to look at it… go with your gut instinct…
