WKO+/Polar question
Most times that I try to download my data from my Polar S625X via the new style IR receiver it crashes my laptop and sends it to a MS Dos type blue window.
The question I have is whether I need to have the Polar Pro Trainer loaded to be able to still download data? I know I have to have Power agent loaded to use my PT, and have experienced no trouble with that but is it the case with Polar?
The blue window disappears too quickly to take down the information but the gist of what I could get what that it had failed. If this was the first time to restart if it happened before…
Then I am sent to the DOS restart page with the standard options to restart in Safe mode or normal windows restart.
I have zero experience with WKO+. I recently bought First Beat Tech software and it allows me to upload my R-R data file straight from the watch, and not via Pro Trainer 5, I am not sure if WKO allows upload from device or from a folder. I would contact WKO+ tech support.
I used to have the 725, but had the protrainer software. If you don’t have the software, how would you upload the info? Are you trying to upload directly to wko? Have you updated your device manager from training peaks? If you have the protrainer software, download it, and drag your file from that and drop into wko.
I have both software programmes installed. In the past I have just downloaded directly to WKO+ by selecting the device on my home page in application settings and then start download in training device download.
I didn’t like the duplication of effort to download in the protrainer software and then try to drag it over, which is unnecessary if you can just download directly into the WKO+. Plus I like the fact that if you download direct to WKO+ all the data files from all of your devices are in the same format and use full WKO+ functionality.
I totally understand, I felt the same way but gave up with the IRA and just did it with the polar software first because I wasn’t too familiar with the wko yet. I just found the Ira to be a pain because sometimes it took longer to download than to do a workout. If you call their customer support, they are usually pretty helpful, I’ve never done it for software problems but you’ve got nothing to lose. Good luck.
I removed the Polar Protrainer programme this evening and then effortlessly downloaded ALL my polar files from the unit straight to WKO+!
Dare I say it weems to have solved the problem? Hopefully.
Well done! I’m not much of a computer guru. Wish I could’ve helped more! Good luck this season.
Me neither, but if we can spread info on what wroks…
Thanks, safe racing to you too.
