With these fit numbers, what size P3C and P2C
The fit numbers below are from competitivecyclist.com’s Fit Calculator. I currently ride a medium QR Caliente. I am wondering what others think would be the better sized bike between the P2C and P3C in 54 or 56cm. Yes, I realize all the normal caveats: head tube taller on P2C than P3C and never buy a bike without being fitted first, etc.
Measurements
Inseam: 33
Trunk: 26.5
Forearm: 13.5
Arm: 25.5
Thigh: 21.5
Lower Leg: 21.5
Sternal Notch: 57.5
Total Body Height: 71
The Aero Fit
Top Tube Range: 53.5 - 55.5
Stem Length Range: 8.0 - 10.0
Saddle-Bottom Bracket Position: 75.4
Saddle-Pedal Position: 92.6
Saddle-Ground Position: 100.4
Cranklength: 175.0
Aero Bar Size: M
Saddle-Aero Bar Pad Drop Minimal: 5.8
Saddle-Aero Bar Pad Drop Moderate: 11.1
Saddle-Aero Bar Pad Drop Intense: 13.4
Saddle-Aero Bar Pad Drop Maximal: 17.1
Pad-Ground Position Minimal: 94.6
Pad-Ground Position Moderate: 89.3
Pad-Ground Position Intense: 87.0
Pad-Ground Position Maximal: 83.3
I’m not sure how to take all the measurements you took but your total body height and inseam are almost exactly the same as mine. I ride a 54cm P3C and I think the fit is perfect though I dont have much to compare to. One LBS said I could maybe fit on a 51 but I think that may be too tight. Below is a pic of me in aero on this bike. Feel free to PM me and tell me where to take the other measurements and I’ll let you know what they are.
http://i66.photobucket.com/albums/h260/surfingsd/Bike.jpg
56cm sitting darn steep on the P3. Likely the same on the P2 but no spacers. Oddly enough, on a hilly course, the 56cm P2 could be the nicer riding choice.
