I have a chance to get an excellent deal on both helmets - which one would be best? I cannot try them on due to where we live being ages away from bike stores. A little worried about the lack of vents in the selector though
i would try the selector first as the tail configurations make it very versatile for different back types. it has 2 sizes where as the rudy project has only 1.
either way, those are the only 2 aero helmets id consider using.
the heat issue with helmets is pretty overrated. i use the rudy project wingspan with the vents closed, tail opened, and taped rear vents.
thanks for that! can get both pretty cheap so will be a good deal either way!
Wingspan is only available in Small/Medium…may want to try it on unless you know you have a small dome.
i have a 58cm dome and the wingspan apparently goes to 60cm? according to rudy project website…
if youre a 58cm the wingspan will definitely fit. but youll need a M/L in the selector.
thanks - pretty rare down these parts so trying on isn’t best option unfortunately. but i know i fit both brands well
The Selector Large fits better for me but my head size is ever so slightly above average. The largest size available in the Wingspan runs really tight and I couldn’t even put it on. So you should make sure the store has a return policy if you decide to get the Wingspan.
I’d probably blow up pics of both of them then try to figure out which fits you back shape better.
I have a wingspan, ride with a flat to very small hump and the wingspan isn’t the best choice for me.
This link has some pics on how it fits me that might help you out.
http://forum.slowtwitch.com/gforum.cgi?post=3284429;search_string=aero%20geeks;#3284429
thanks for that - i think maybe the selector would fit me better
Can you share where you’re getting an excellent deal?
I need to get another Selector since I damaged it in a crash (better than damaging my head, I guess) in the only race I used it this year.
unfortunatley i cant as there is only one helmet sorry
youd probably do pretty well in the selector with the full tail or the specialized tt2 with all the vents taped and covered with a closed tail.
I wear a 7 3/4" fitted cap and was worried about the wingspan. They were at an expo with product so I tried it on and it fit great so I grabbed it. Anything bigger might be tight though as I have it all the way open.
trademe?
No not trademe - but I did see that one. Went for about 300 bucks didn’t it?
unfortunatley i cant as there is only one helmet sorry:( was hoping you could share, too. Oh well.
