Hey Guys,
Going to the wind tunnel in Seattle on May 10th, looking for some collective wisdom from ST on suggestions for testing.
I have had a few conversations with Len Brownlee and Carl Hoefler and I believe I am in very good hands.
Just looking at some input as to how I should go about this. I read James Haycraft post about pre-testing and his blog about the results…great info.
To start, I own a P5 stinger disk and H3 front. As per advice (zero yaw tunnel) I don’t intend on changing wheels. I will cut shifter cables to make the transitions from run to run easier. Also the base bar is slammed, I like it that way and with hydraulics etc it would be hard to manipulate. Also I have a selector, but I may or may not have the ability to try other helmets. Only issue is that I changed the tire on my H3 and it is 23 mm (only one I had) it will be the same for all runs though
My thoughts on testing:
Run 1) Base line position (high V) with standard tri suit.
Run 2) Base line as above but with castelli body paint full sleeve (I believe old version 2.0)
Run 3) Base line as run 2 but with q-factor or pedal stance at 12 mm wider.
*I want to test this as I have not seen much info on q-factor and how it affects CDA, I have 2 sets of pedals with 49mm and 55mm axels. I am also not sure if wider is better or worse with say a P5 or other “super bike”
Run 4) Base line with elbows tight in about 3cm, will stay with the pedals that offer better CDA
Now……I have 6 runs left, Maybe 4-5.
Obviously I will go lower, I am debating to “waste” a run on road helmet vs selector, if there are no helmets. IE base line crap vs what I think is a fast helmet. Also debating extensions I have some straight and s-bend, it would be easy to swap out with out shifters.
Also debating an out of the saddle run, I think this would be interesting data but likely of little value in terms of making me faster. Also after thinking about it I believe that the side to side motion of real world climbing would be different than being locked in to a stand in the tunnel.
So….I was thinking,
Run 5) low position with elbows tight
Run 6) low with elbows back to normal width.
As some have said in other posts, leave room for trends. I have set up runs 1-6 in order to have the least amount of down time. I am thinking of runs 7-10 would free form or to follow trends or unexpected ideas/positions etc.
Appreciate any feed back.
Maurice
