Will it? Or will it rub? Does anyone know for sure?
The Jet disc comes in 2 widths…C2 and the old normal “skinny”…you will want the skinny and you will have no problems.
Narrow one will work for sure- Don’t know about the C2. It should- A sub 9 works with a Transition and I am pretty sure it is fatter than the Hed C2.
thanks. . . If the Zipp will work then the C2 should no problem.
Jst make sure to check your brakes out and set them up for the disc ahead of time-
HED was going to do away with the skinny and one of the reasons they are keeping the skinny and not exculsively going with the C2 is the narrow stays of the Transition. I have talked specifically with HED about this. It may be on their website too. I have a skinny Jet disc on order to use with my 2008 S-works Transition.
Yes, on the website it talks about the skinny and normal disc. Thanks for pointing that out to me. I appreciate the help.
Does anyone know if a Hed C2 Disc will work on a 2010 Transition and also on a P3 ?
Is HED only making the C2 disc now and no skinny version?
Thanks ![]()
