Quick question,
Will a 2-3 year old dura-ace double crankarm work as a replacement crankarm on a (2002) 105 triple? I want to keep the triple want to try out the differentlength of this crank arm. I can’t tell if it is compatible.
Quick question,
As long as the BB type is the same…yes.
From what I can tell that is the case. Thanks.
I would assume the spindle length of your BB would be different.
Generally
Doubles use: 109.5 mm
Triples use: 118 mm
But I won’t be changing the BB, right? I am going from triple to triple.
Thanks
Sorry. Read your post incorrectly. Though you were going from triple to double. You should be good to go.
