Will a Hed Jet Disc fit on a Speed Concept?
I know there are issues with a wheel cover rubbing the Duotrap port on the Speed Concept (depending on the specific rim/hub on which the cover is mounted). But what about a Hed Jet Disc - will it clear the Duotrap?
I use that setup fine. Lots of space. I even glued a rare earth magnet inside the the carbon of the disc for the duotrap.
Thanks. I’ve never actually laid hands on one. How were you able to gain access to the inside of the cover?
Through the valve stem cutout. Since the disc is just a spoked wheel with a fairing, there’s lots of space in there to fix a magnet to.
I get that. I just thought you’d have to get way down there (ie. closer to the hub than the rim) to be in the vicinity of the Duotrap. I’ll have to look more closely next time I’m at the LBS.
I’ve done it for two years. All you need is a basic adhesive wheel magnet. I’m about to put my Hed Jet Disc up for sale of interested.
Last time I checked, all true discs fit a speed concept. Its the wheel builder covers that (sometimes) don’t.
For what its worth I run a stinger 9 front/disc rear setup with no problems, you just gotta get the brake track’s as far apart as possible.
