Why would you change HR zones?
I haven’t given Paulo a chance to make fun of me yet today so i decided to post another stupid question from the peanut gallery over here…
I’ve read a couple things on here about people changing their HR zones after they have been training for a while. Why would you change the HR zones and not just the pace zones in the short term. I don’t mean in comparison to when you are 25 and 35.
Like right now i run my 5k at 196-198 bpm avg hr. If i were to get faster wouldn’t i still be able to run at that same hr just at a different speed. If so wouldn’t that mean i should only adjust my speed zones, until a noticable drop in HR in the long term??
Grant
anybody?
Grant
Grant,
I don’t think your top-end zones are going to change much. But your lower-end zones e.g. AT & AeT (I haven’t had Paulo make fun of me yet today either :wink: are much more sensitive to training and can change pretty markedly.
Cheers,
Alan
perhaps if you found out your assumed HRmax was wrong? Can’t see why else
Yes you are right, you’d be able to run faster at the same HR.
If over time, with training, you raised your LT, then that could be a reason to adjust your zones.
Grant
As you gain fitness (esp. cardiovascular), your heart rate at any given absolute exercise intensity (VO2, pace, power) will tend to decrease. OTOH, as you gain fitness (esp. metabolic), the absolute exercise intensity that you can maintain for any given duration will tend to increase. These two opposing tendencies obviously tend to cancel each other, which limits the change in heart rate at any given relative intensity (e.g., the maximum that you can maintain for 30 min). Nonetheless, the heart rate which you can (should) train may still go up or down somewhat, which is why it is a good idea to periodically revisit your “zones”.
(Note that the above also applies should you choose to base your training zones on maximal heart rate, since LT will tend to move closer to VO2max, but maximal heart rate itself will tend to decrease.)
How would you adjust your lower zones then? Are percentages of your LT or max not the best way?
Grant
In my mind, the best way of setting up your zones is by testing AeT, AT & Max heart rates individually.
The first 2 via a step test, the last via an all-out TT of short duration.
If you are setting them up based on % of MHR, you will definitely need to take into account individual fitness. E.g. 75% MHR for an elite is a whole different metabolic picture than 75% MHR for Joe Couchpotato.
Hope this helps.
Alan
What is the importance of knowing the Max HR for the prescription of exercise? Here’s a possible answer: ZERO importance.
Stop answering a question with a question thats just not nice lol.
Grant
There he is!
I wouldn’t say zero. I would prefer to know what % of VO2max AeT and AT occur at but even knowing what % of maximal HR gives me some info as to the relative fitness of a given individual.
Alan
It does manage to find its way into a lot of books.
There he is!
Alan
Never mind that there isn’t any evidence that validates that measure of “relative fitness”.
And Barry, I have a little homework for you. Find the paper where the “220-age” formula appears. You know, a paper where they measure the Max HR of a bunch of people, plotted against age and saw a correlation with it. I wish you the best of luck!
There he is!
Alan
Paulo - have you read Fitness Myths? it discusses 220-age in the book. I think a lot of people would be surprised why its used. See my above post for more.
Are you seriously going to argue that Joe Nobody can hold the same % of MHR for 8hrs as, say, Peter Reid ?
Alan
Alan, give me a break… I’m just trying to bust some myths here, one is the use of Max HR. The 80’s are over. If you want to keep using it, be my guest. I for one don’t like to make my athletes go through a worthless and painful test so that I can have a number that is “neat”.
Fair comment, P-Dog. :slight_smile:
