Why not geoprene (limestone) for wetsuits?
A short blurb I saw was talking about geoprene, an alternative to neoprene (petroleum-based), made out of 99.7% limestone. It was developed by Yamamato back in the 70’s and offers such benefits as:
  • 98% water impermeabilty (versus Neoprene’s 70% water impermeabilty)
  • Offers this impermeability at half the thickness (so you would need only 1mm of geoprene versus 2mm of neoprene for the same benefits of warmth)
  • Lasts twice as long as neoprene.
There are a couple if not more companies that are selling wetsuits made out of this material (Matuse and Patagonia, for example). They seem to be surfing-focused though. So, my question is why aren’t triathlon wetsuit manufacturers using this material?
Other than cost potentially, it seems to offer better flexibility and warmth.
Kendall
Triathlon wetsuits are all about flotation, not warmth. Geoprene would need to be more buoyant and flexible than neoprene to serve the needs of the tri market.
I think you answered all of your own questions:
98% water impermeability equals a hot, hot swimmer with potentially horrible effects.
A durable wetsuit means less spending by consumers on the newest, hottest, most marketed toys that come out the next year.
As triathletes I don’t think we demand a quality product, only a fast and expensive one. I think surfers are more likely to respond to quality over the “Bling” factor
Maybe I am being impermeable here, but I don’t think that water permeability contributes any significant factor to how hot a wetsuit feels. It’s all about surface coverage, insulation factor and boundry(bulk) temperatures. I highly doubt water flows through (not into) the wetsuit when swimming.
Kendall
what makes you say the flexibility is better? they may be able to use less thickness for the same coverage, but 1mm of stone is still less flexible than 5mm of plastic wrap :wink:
cheers!
-mistress k
The material is derived from limestone and at least as flexible as neoprene from what I understand. A thinner wetsuit would allow more flexibility. Maybe you wouldn’t want it in the core or legs where you want maximum buoyancy (and thicker material would provide this) but why not in the shoulders or across the back where you might want that flexibility. Perhaps some type of hybrid suit.
Kendall
That material is definitely warmer then neoprene wet suits. I’ve never done a comparison, but I may suspect too warm for a longer and/or warmer swim. If it was short, or colder water. The material may be ok.
you mean something like this?
http://www.tyr.com/sayonara/
Warmth is a pretty secondary feature for most triathlon swimmers. The real benefit - and the reason the pros wear them - is displacement. So making the suit half as thick would be a bad thing.
The question is what is buoyancy of geoprene versus neoprene - do you have an answer?
On a related note, my surfing wetsuits are 10 times more flexible than my triathlon wetsuit, but not nearly as buoyant. You don’t want buoyancy at all for a surfing suit so it’s easy to duckdive under the waves.
