Well, we have once again been steered off course with this spearing concept. While spearing poses a risk, it is not the reason… …The risk of aero bars actually spearing someone is about as likely as having your uncapped drop bar end gouging out your leg in a crash. It isn’t likely, but they still like to have the end caps in there. Removing aero bars certainly removes that risk, but that risk had nothing to do with the decision to ban aero bars from mass start racing.
Not true. The UCI specifically mentioned the fact that protruding extensions were by definition a hazard when they banned – after having initially OK’d --the old Cinelli* Spinacci* (sp?) mini-clip-on bars for pack racing.
Bear in mind that they did this despite the fact that Spinaccis extended less than half as far as aero bars, and were angled in, rather than sticking straight out. They were safe as hell steeringwise, and had been used in multiple mountainous stage races before being banned – no worse than riding with your hands close together on the tops.
On your other: the prong of an aerobar faces forward and is centrally located with the riders full weight behind it – in a crash, it’s a hazard to the head/face/neck/back of everything that’s not moving any more while you still* are* – probably at 30+mph. That’s a lot different from hitting your own uncapped (? why?) drop bar end with your leg, when both you and the bike are moving forward to some degree.
If you think the possibility of an aerobar spearing you is freakish because the bar doesn’t extent beyond the front wheel, go watch that stage 1 wreck again.
Trailing riders commonly hit the ones already down; this often twists their frame sideways at the same time the ass end of the bike comes up (because the front wheel is fully blocked by the ‘obstruction’ – e.g., you or your bike, if you’re on the deck).
Is this risk significantly more dangerous than getting hit with the handlebar itself? Ask any hockey player whether, given the choice, he’d prefer to be crossckecked acoss the back, or speared with the stick’s butt end.
Now, switching back from hockey to cycling, multiple the mass and acceleration components of that “f=mv squared” impact about fivefold. Trust me, in this one case at least, the UCI knows what it’s doing.
