Why is my sump pump beeping?
It’s raining outside pretty hard
It’s going to blow. Get the fuck out.
I cut the blue wire and the alarm stopped
So the alarm did actually go off on its own, paying 250 bucks to have someone come out since the basement is finished and it is pissing outside
Maybe it’s in reverse?
One of my primaries failed. This will be a quick 900 bucks… eyeroll emoji
Learned a lot tonight although not cheap
Is the sump for drainage only or is there a basement toilet tied into it?
Maurice
Maurice
Drainage. Two sumps three total pumps.
I have an injection pump in a different location for the bathroom
Maurice
Ahh ok, just checking the obvious.
Maurice
Maurice
Maurice
One of the primary pumps went down. Had a guy come out and replace it. Almost flooded in the time it took him to swap out. We had a real bad rain storm.
Maurice
Maurice
I bet you can pull a pump now, I wonder if it’s worth it to buy a spare for when the other fails. Isn’t this a newer house?
Maurice
Wait two sumps and three pumps and basement almost floods when one is down? Did he have to switch off the backup while he was switching out the primary. If not sounds like your backup isn’t enough. Our backup runs on municipal water pressure so no lectricity required. Maybe not an option if you live in the country.
