Yes, I know there are many variables, but with repetition, variables tend to cancel each other out. …
A common misconception. Too many uncontrolled variables make the results entirely unreliable – the bad variables don’t just cancel each other out, they also drown out any useful information. Even more importantly, they cause the experiment itself to be *misspecified. *A badly designed experiment with good data collection is still a bad experiment.
The most important variable that has to be controlled is the cyclists’ effort. Over the course of a season, on identical bikes and tires, our times can easily be in a 2-3 minute window over even a short race like a 20k. That is due to the weekly rise and fall in fitness. There is no way you can make reliable aero or tire decisions with that much movement in power output. HR monitoring is pointless, since power output will rise and fall, at the same HR levels, all season long.
What *has *been done that involves a well-specified experiment is to ride identical courses under the same conditions, with a powermeter. By “same” conditions, we mean without hills and without wind. Tires have been tested on the track by numerous publications and hobbyists. Tires have been tested on road circuit under carefully controlled conditions by various investigators (myself included). They all come up with the same results as the guys testing on drums. (As an aside, know how Michelin tests F1 race tires for Crr? On a drum. Why? Because it works.)
What puzzles me is that, no matter how the test is designed, the retro-crank tubular folks will always chortle and dismiss the test. Test on a drum, they say “not real roads”. Test on a track, they say “not on asphalt.” Test on an asphalt road, and they just say “I don’t believe the test.” Hmm.
Every test and every set of conditions leads to the same data result. Still, there are those who will never believe that a clincher can be as fast as a tubular, for the sole reason that, “If clinchers are so fast, why do pro cyclists ride tubulars?” I can’t answer that question, but I can wonder why anyone would put the decisions of a pro cyclist on a pedestal. Isn’t it sort of obvious by now that pro cyclists, as a group, aren’t the wisest and most thoughtful athletes around?
*All that given – *The reason some of us started doing these tests is that we DID see differences in our race times between the two tire types – differences that couldn’t be readily explained. With the same power output under similar circumstances, we couldn’t figure why our times didn’t make sense. A few summers ago, I was scratching my head when my race times with 404s and tubulars were worse than my practice times using training wheels and clinchers. I rode the same course a few times a week, training with a powermeter. Then I’d do the race on the same bike, with the same powermeter, using my expensive wheels and tires, and end up with slightly worse speeds at given power levels! On other forums, I met people finding the same thing going on. We started running tests and every person came up with the same facts.
Those facts lead to a simple conclusion.
