Why does PT use a serial port to transfer the data from the PT computer to your PC/Mac? Why not make it in USB which would be 1) faster and 2) compatible with all newer computers?
how about no reason, other than the company being behind the times?
Because it is much simpler to program for RS232 connections than it is for USB. Simple as that. Besides, it works doesnt it?
While you’re asking why, you might as well add Computrainer and Garmin GPS to your list.
One of the Sales reps from CT told me the engineers are reluctant to update the mundane stuff. I don’t know it that is a cop out or not, but this coming from a company that is still only working with non-coded polar transmitter straps. It’s not as old as the serial port, but it certainly is heading in the same direction, just behind the 3.5" floppy drive and the Parallel printer port.
I think it has more to do with the fact that the serial port is relatively low-tech but still provides a reliable data upload capability that usually need not be super fast as it is rarely used for real-time high-speed data exchange. and when it is the software using it isn’t so sophisicated that the serial port can’t keep up with it (i.e. CT’s 3D, PC1, CS, or some of the GPS program that will display satellite locations and data)
Jim
I work for a small technology company and we probably have the same criteria for upgrades as CT and PT - will it make us more money?
How many people considering the purchase of a CT chose not to because of the USB/serial port? Probably none. Compare that lost revenue ($0) with wages and lost opportunity cost of having your limited number of developers working on USB programming.
Same question for PT. You probably looked at price, reliability, accuracy, ease of use of the bike computer. If you looked at the transfer mechanism at all, it was probably far down the list.
Probably because many users or potential users have an older PC (without USB) sitting around that they use for their bike stuff. RS232 works, and the RS232 - USB adapters work also. PC’s are cheap, but not not cheap enough for everyone to run out and buy a new one just to run their CT or PT.
Thank god they don’t require coded straps. The coded straps are just a money making opportunity for Polar. I have run the past six bike races without a strap and only for about five minutes out of six hours do I pick up someone elses heart rate strap (otherwise heart rate data is zero). It’s a solution to a problem that is miniscule at best.
yes it works if you have a serial port. otherwise you have to go out and buy an adapter. I purchased my laptop 1.5years ago, it has 5 USB ports but no serial. How many computer come with serial ports those days. I get your point that it is much simpler to program and someone else mentioned the associated cost which can be avoided by simply sticking with the serial version. Nevertheless, I think it is kind of week that it requires a serial port.
thanks, completely makes sense.
It’s a solution to a problem that is miniscule at best. I think it is application dependant. we used to rotinely screw with a buddy at the track who have a much lower HR than the rest of us. One of us would run an interval closer to him than normal and watch him freak when he saw a super high - for him- HR
During the race did you pick up someone elses signal because they were on the same channel or you weren’t close enough to recive them.
Wheather it’s a Polar gimmick or not (I don’t think it is) bottomline: that is where Polar’s technology is headed and until somebody better comes along I think they are currently the HRM industry leader.
How hard would it be for CT to offer a reciever that does both? Polar already has different sized the circuit cards for coded and noncoded signals to go into treadmills, and we are only talking about a stereo plug connector.
My pipe dream hope is that CT has been out-of-stock for the last six months becuase thaty are re-working the module.
Point taken. I think they may not see their main market as multisport athletes. Same with SRM and Ergomo. SRM still requires non coded straps and uses the serial port.
As an aside, I always had a problem with my coded strap and the Polar losing sync and dropping data (not a heavy sweater in the chest area.). Never have that problem with non coded systems on Polar/Performance/SRM/PowerTap.
Serial is faster then USB, most ports are faster then USB in fact. USB has with it it’s own host of issues with compatibility across OS’s. A USB device that works on W2K may not be so hot on XP SP2, but works fine on SP1.
The trouble with this is that it is very time consuming to support all those OS’s with the end users of varying computer skills of which many people are simply incapable of following directions. Serial is less demanding to support once the product is in the field.
USB has it’s uses but in a ruggedized world, they should be the last choice for a data port.
“Serial is faster then USB, most ports are faster then USB in fact.”
Say what? RS232 is a LDR (low data rate) interface, with data rates up to around 128Kbps. USB is MDR (medium data rate), with rates ranging from 1.5Mbps (USB 1.0) and 480Mbps (2.0). By comparison, Firewire-A (marketed as Firewire 400) is 400Mbps and virtually indistinguishable from USB 2.0. Firewire-B (marketed as Firewire 800) doubles that to 800Mbps.
RS232 is 1960’s tech, emergining somewhere around 1962…and is, by today’s standards, ultra simple. Its a basic interface with a huge support base that isn’t going away as soon as folks thought…The physical interface can be ruggedized and supports longer cable runs than, say, USB or Firewire. RS232 is super cheap these days. But none of this is really important to PC or Mac home users. What matters, and why these companies chose RS232 initially is that 128Kbps is far more than is needed to transfer the tiny bit of data. I have no idea what the size of the data packet(s) that these devices use, but it is simple data…we’re not talking about streaming video or audio…or even that ungainly 80MB Powerpoint presentation you created with all the gaudy graphics and animation.
The problem is…if you’ve bought a PC or Mac in the last 3-4 years…particularly a laptop…chances are you don’t have a RS232 port. My Mac Powerbooks don’t have one. Neither does a friend of mine’s Vaio laptop…In the PC/Mac home computing market…RS232 is disappearing at the rapid rate…Frankly…its time for CT, SRM, CycleOps et al to get with the times. (Unless, of course, they have a kickback relationship with companies like Keyspan who produce serial to USB adapters ![]()
