Why am I slower with paddles?
yeah, but I’m certain it isn’t the first time he’s done that set, so he knows how to pace it. just that he can’t swim as fast when he sticks the paddles on.
if I do 2 sets of (8x50), the first time through is swim, 2nd time is pull, then I’ll be going slower on the second set. it isn’t a pacing issue, it’s that I’m slower at pull than swim.
same thing with the OP. the assumption has to be that he knows how to pace the set, there was a change at the halfway point, and that change caused him to slow down. not that he’s too fatigued to complete a relatively easy set of 50’s.
In the “you can’t suck and blow” department, maybe when he uses paddles he forgets to kick!
why not ditch the paddles all together. They are a decent tool. But not needed to improve. If they are giving you trouble, why bother.
Oh and Jason is likely right: you’re pull is too deep.
I use the term “strength based” for people who use power to overcome stroke inefficiencies (masher on a bike).
Once again not people you would typically swim with in a swim (fish) based group, but would in a Tri (brick) based group.
If a guy runs out of energy after one set of 8-50’s at between 35 -40 secs, you have to believe he’s pushing.
Sun Yang may be a strong swimmer even by Olympic swimming standards, but his dps is also otherworldly.
(too bad he dopes just a teensy weensy bit)
You gotta go swim with a Tri group to know what they are capable of, before applying your level of strength and stroke efficiency to them.
Really, it’s a different world.
In your world I’m in lane 7 (in a 6 lane pool :0), in a Tri swim group sub 40, 50’s for more than 1 set, would lead the group.
(a lot of the time).
It’s one of the problems that comes about when swimmers give TRi guys advice.
It’s like having Abebe Bikila explain running to me.
couple of fallacies in there
  1. a masher isn’t necessarily less efficient on the bike, or in the pool.
  2. I do know how triathletes swim, and the good ones listen to what the swimmers have to say. The poor ones often don’t. I’ve gone too hard and blown up on more sets in a month than they’ll do all year. I understand what happens when you lose stroke efficiency, because that’s what happens when you blow up in a set. The trick is training yourself to maintain that efficiency as best you can…
  3. I’d bet Bikila can explain run mechanics to you better than your average triathlete.
there is a saying, “fake it til you make it” That basically means that even if you are a crappy swimmer, pretend to swim like a good one. Eventually, that pretending to swim like a good swimmer results in you actually swimming like a good swimmer.
Do you use the wrist strap? Try the paddles without using the wrist strap, if the paddle comes off then there’s a stroke/water entry problem. if you can use the paddles less wrist strap, chances are you don’t have significant stroke flaws while using them.
we have to stop meeting like this.
Why wouldn’t you be slower with paddles?
Do you have great swim form, very strong swim specific muscles, and a limit to your turnover.
No- most swimmers don’t meet all of these conditions either.
How would you know?
Didn’t see the 200m paddle swim at the last masters meet.
I have seen paddles used for form and strength.
Well truthfully if you are a fish you should be able to at least match your non paddle 50 with a slower turnover.
If you aren’t a fish you will not have either the strength or the endurance for them (for fast 50’s)
I don’t believe you get much out of using paddles that are too big, I also don’t think racing in them is a good idea.
And they don’t have snorkel races, or swimfin races at Masters meets either.
Mores the pity, I’m wicked in fins.
Those people who burn out early that you’re describing are almost certainly slower than you even for short sets. They’re just pacing their workouts incorrectly and thus burning out quickly. If you pushed as hard as they did for your ability on the early sets, I’ll guarantee you’ll be beating them on those short sets.
the “pull is too deep” was my guess as well - haven’t seen him swim, but, that bit of mechanics really matters, and, I’ll submit is a technique differentiator of significance.
