Who has been diagnosed with leg and foot issues?
Who here has been diagnosed with leg and foot issues, and what have you done to protect yourself and/or change your running, biking (and swimming, if it pertains?)
Thanks to RRoof, (foot dr extraordinaire) I visited a local podiatrist: Dr. Pribut, a popular running-injuries doctor on the web. The good doc (and Rod) diagnosed several pathologies of my legs and feet which have been plaguing me for years, but I thought were very ‘normal’ *
What have YOU done to help yourself - and do you still have pain and/or pathologies?
Lauren
*The doc said I have:
-one leg shorter than the other, which is very evident in my gait
-forefoot varus (turning of my foot) when walking and running
-very limited foot ROM creating ‘equinus’ in the rear leg muscles
-Morton’s foot, which means that my metatarsal bones are the wrong length, creating no flat surface to stand
All these created all the severely painful running, walking and cycling issues I have encountered for 30 years… but I thought I ‘couldn’t learn’ good technique!
better question is, what can be done about all that?
My left leg is 20mm (confirmed by calibrated X-ray imaging) shorter than my right
forefoot varus (turning of my foot) in both feet, but especially my left
both knees roll inward
severe over-pronation
Morton’s neuroma in both feet, worse in my left
A combination of custom orthotics, lifts (in the orthotics and in the left sole of my Rocket 7s) and 2 cortisone injections in each foot have effectively countered all of the symptoms.
Chris
“better question is, what can be done about all that?”
I am starting with a few solutions, including a shim in the shorter-leg’s heel, plus some OTC orthotics to begin. I have to do stretches and yoga to keep my muscles pliable from being pulled in their funny directions. We will see if my insurance will cover custom orthotics. I will also have to monitor the pain and tightness, and maybe switch sports if need be.
Well, Lauren,
I have all of the consequences of being an overpronator; as well as recurrent plantar fasciitis (which is blooming nicely right now, thank you very much!). Have also broken and sprained both ankles multiple times, with resulting degenerative joint disease in both ankles.
Other than the occasional use of orthotics, stretching / yoga, and symptomatic treatment, I have done very little to alter or preclude my pathologies. Oh, and I switched from being ‘just a runner’ to triathlon to enjoy the myriad and sublime benefits of sucking at three sports instead of one!
I am just about the same as you, but without the neuroma. Just about the same leg length discrepency also. (about 20mm)
Thanks for the info…
Well I must say Lauren, you do “tackle” things head on! Good for you. But I for one don’t want you to give up on running just yet :slight_smile:
Good luck!
“you do “tackle” things head on! Good for you.”
LOL!!! … duh! Coach! (points at self)
Not giving up running yet :slight_smile: – don’t worry. The squirrels will have someone to keep them company as they scurry slowly :wink:
Lauren
as Doc Roof says, keep fighting the good fight. Keep trying new treatments.
I’ve been diagnosed with:
leg length discrepancy
over-pronation
among other things I can’t remember the names of.
and had injuries such as shin splints, ITB, yadda yadda yadda.
I spent countless hours in rehab, and have had orthotics made by three different people by three different methods. And I spent a bunch of money on stability shoes and motion control shoes.
Turns out all I had to do was ditch all the gizmos, get a nice pair of Nike Waffle racers, and stretch more.
No problem, Lauren. A few more specifics, in case they help.
I got some video of me walking / running barefoot and in uncorrected running footwear to use in diagnosis and as a baseline.
My podiatrist told me that my ankle and foot flexibility has been (unknown to me) a big help in adapting to the various problems, and encouraged me to maintain that flexibility.
I have a 7-8 mm full-length lift in my left running orthotic, and 5-6 in my left cycling orthotic. I first used the cycling ones in my old cycling shoes (some Sidi Genius 4s) to get used to this smaller amount of change in effective leg geometry.
After a month or two of using the new running orthotic we re-did the video and there was significant improvement. After getting used to the cycling orthotics I then had some custom Rocket 7 shoes built with a 10mm thicker left sole. I had them leave out their footbed to make room for my orthotics. The only hitch here was there there was an interaction between the number of cleat holes they could drill and the maximum additional sole depth, so I wound up needing a Crank Brothers 2-hole to 3-hole (or maybe it was a 3 to 2) adapter so I could still use my bebop pedals / cleats.
Thanks, Chris, this is wonderful help and understanding of the process! Thanks! I also now realize how common these issues are!
Lauren
