Would you believe a sub 13 lb steel road bike?
Probably rides smooth as silk…carbon rear end IS cheating though.
Since there are only 4 steel tubes and they are in a compact frame then it isn’t really that special in and of itself. I could probably make a 15-pound bike out of my old '87 Cannondale if I spent enough money.
Chad
that bike is awesome. i wish the rear triangle was steel as well. would be a bit cooler. throwing that in a backpack would be the ultimate travel bike!
Hi Cerveloguy: Marinoni (sp) have some light and stiff steel bikes.
Hey by the way Did the resolution run to-day. Cerveloguy after the article in the tri mag, I cannot have enough respect for what your speedy lady races with. You are truly blessed (except for the chillllllie she ate to-day) you obviously treat, and treat her right!!
Rick
Cervelo dependent since 2005
Keep going EAGLES!!
What’s the big deal? It’s a 1.5 + kilo frame (that’s not particularly light, even with an S&S kit,) and half of the bike is carbon fiber, straight out of the box from Deda.
For $13,000 I would expect a hell of a lot more than that…
She had a decent race. I skipped it the resolution run year. Just being lazy I guess. Did go for a run though with my dog on the trail and then did a trainer ride with Coach Troy. Getting back into it now after taking a couple of months off.
“What’s the big deal?”
I guess my point was that steel bikes aren’t that heavy. It’s quite easy to build up a 15 lb steel bike with today’s components. My hint was that carbon is way over hyped and steel is ready for a come back. You can get a top end custom steel frame from a custom builder for half of what you’d pay for a higher end carbon frame.
I have 2 steel frames that are both sub-3 pounds. With the light weight tubes available, relatively light steel frames are not that hard to come by.
and it looks like it has SS couplers as well
I clicked on the picture to see if I can get a bigger image to take a look at the rear derailleur. It didn’t open, but I think I dented the downtube.
I have a custom steel frame road bike. fully loaded it is 19lbs. not that light but it is a 64cm frame.
