I guess SRAM Red does not work. Any suggestions? Thanks
Dura Ace, Tektro R410 (I think thats the #, I’ll check when I get to work tomorrow), NOT Ultegra, Chorus (although the crank to pinch-bolt clearance is extremely tight, but doable)
-cory
Just be wary because some brakes will fit but will then hit certain cranks. For example Rappstar ended up using an oval concepts a700 brake to fit around his zipp vuma quad cranks (Sram won’t work). Tektro puts out the same brake (not sure the code) as does TRP (the TRP T925).
If you search for threads you’ll find some comments.
Yeah I have a Felt DA with vuma quad and had a nightmare finding a brake to fit. I used an oval a700 to fit but it still takes a bit of adjustment, like using spacers on between the brake arms and pads… good luck
see my thread on “rate my ride STEALTH BOMBER” for more pictures!!
I vote for Zero Gravity Ti brakes.
Dura Ace 7800, or any of the brakes use at the OEM level on any of the production bikes.
The issue with SRAM is they do not fit between the crank arms. The caliper will fit into the frame, but there are no cranks that will clear them in this location.
Dave
As above I use an oval brake, but this then takes away a little aero advantage gained elsewhere due to the angle of the cabling. I’m so happy with my bike it rides like a dream, but do you have any idea for a brake that will fit with the vuma quad without the cable going under the bike and use the proper route? Thanks dude!!
these work very well back there…
I have a single rear (I used the hooker front on my DA)… if the OP wants it, drop me a PM.
g
