Not that anyone has mentioned it but,…avoid SRM IMO. I’m on my third one, the first PC5 I had was flawless, second PC5 had a cracked housing, third is a full boogie PC7 and while it works well the slope has been out -10/20 watts right from the factory. Pretty annoying, I’ve tested it and confirmed it but the slope does not hold on the newer ones. Also compared it to other PM’s. It always seams to wind up back on automatic so my slope get reset. The PC5’s where better IMO because you could set/check the slope yourself.
The new generation of PTaps are awesome and fairly cheap, but qaurq will be my next PM. Former teammate has had several of them and they all speak the same data.
Quarq CinQo all day every day, and twice on Sunday. It’s a single bolt to swap between bikes and you’ll never be limited to what wheels you run. Maybe you want a disc in the future or decide to get a set of dedicated training wheels so your good race wheels (and more specifically tires) don’t get the daily wear and tear. What if you bend a rim or blow a spoke? Sure, it can be fixed but you’re without your PM even if you borrow a spare wheel. The pedal-based systems will probably work out fine but I wouldn’t want to be in on v1 and end up finding the bugs. I think the players are big enough to handle any issues in time but expect problems initially. Just look at some other Garmin products from the past…definitely not ideal from the get-go.
