Can anyone recommend which bike shoes and brands allow for more rearward cleat placement? It’s pretty much impossible to tell in the shop without actually buying shoes and installing the cleats, so looking for some first hand feedback.
Not first hand but the consensus that I gathered when I looked into this was that Speedplay pedals with the speedplay adapter plate is the way to go. That combo allows the most rearward cleat placement short of drilling new holes in your shoes.
Can I provide a link or firm data on how rearward. No, sorry. But if you google it I’m sure you’ll be able to find the information that I did.
One of the articles was written by a guy who also reviewed those 500 euro shoes which are designed to do the same thing. And there was a thread on weight weenies (I think) on the same topic. BMAN would know.
Yeah, I know, I’m not being particularly helpful. Sorry.
I use Specialized and Sidi shoes with the three hole pattern, Speedplay cleats with the adapter plate moved all the way back. It’s the best I have found, and the hole positions between the two do not vary much.
If it helps, I’ve had shoes re-drilled in the past for $50-60. It’s something you might want to look into. That way you can buy the shoes that fit you best without having to worry if you can get the cleats rearward enough with the stock insert locations.
thanks for the tips. I am actually using Look Keos, and I drilled a set of holes 25mm further back in a set of early 2000’s Time shoes which had the holes further forward than many other shoes. I am looking at replacing the shoes and keeping the Keos so I would like a shoe that doesn’t require additional drilling.
second the speedplay apt. that is what i currently use
