Where is the "peak" in a saddle?
We’ve all heard of the dreaded “5cm behind the BB” UCI rule that will make some of our bike positions illegally steep. Here’s the UCI reg: 1.3.013 The peak of the saddle shall be a minimum of 5 cm to the rear of a vertical plane passing through the bottom bracket spindle1). Is the peak of a saddle the frontmost point, or the highest point? If the latter, wouldn’t that be the back of the saddle?
it’s the “tip” of the saddle.
“Hello we’re from the UCI we are here to help” Run for you life!!!
Dan…
