Where is the fit table for Speed Concept?
Where is the fit table for the Trek Speed Concept?
Judging from their site that goes off your height, I’d be a large (I’m just a hair under 6’ 1") but that is a crude way to fit a super bike.
My measurements:
Pad X (Center) 495
Pad Y 640
Saddle Height 795 cm
Cervelo has a handy sizing tool on their web site:
It looks like I’d be pretty comfortable on a 54cm Cervelo P5 but a 56cm would work as well.
I’d fit on a medium or large P3X.
I’m 6.0 and SC gen2 size L appeared a bit small to me. Had to get mono plug, with longer extensions, smaller crank
https://docplayer.net/23241472-2014-speed-concept-fit-guide-2014-speed-concept-fit-guide.html
I’m 6’-0"
On a Large frame
Medium / Far stem
15mm riser (smallest)
165mm cranks
Pad height 646
Pad reach 535 pad center (but I actually hook my elbows just behind the back of the pad
Saddle height 79.5cm
I’m pretty happy with my fit…
Thanks for the chart and for the confirmation with your measurements.
It looks like I’m a large frame with a medium-far stem, 35 + 5.
You and I seem to have pretty much the same bike fit. If you are looking for a 640 stack height the 15mm riser is the better choice. It’s a pain in the butt to swap them out if you have mechanical shifting. Right now I have some up-tilt on the aero bar which moves the pads up a bit, but the only way for me to go lower would be to swap the stem to a low / far. I’ll check my current pad height but I’m pretty sure it’s at 645.
I definitely can’t go lower than that, in fact, I may need to raise it just a bit.
Thanks for all the help!
