I just got my first flat and used that “tube in a can junk” but the tire was actually punctured and I pulled out a piece of steel wire…the question is…
Can I just put a new tube into it? Should the tire be replaced?
Toss it. A slice through the casing means that you will continually pop tubes. In a pinch you can buy a little time by putting duct tape patch on the inside of the tire. I just replaced a tire with less than 200 miles on it.
