Wheelset differences - need a ballpark estimate
My current wheelset is a set of Mavic Cosmos (they look like low end rims that would come with a midrange road bike around 8 years ago), about 6-8 years old probably with maybe around 20,000+ kms on them.
Approximately what time savings would I get over IM bike with
  1. A set of new Aluminum Aeroheads
  2. A set of new Flashpoint 60s
Based on ~30kph avg speed
Thanks!
flashpoints would probably save you between 4-5 minutes. aeroheads a bit less.
This is a trick question. Based on a 30kph avg. speed you would have no time savings no matter what wheelset you were using.
Bernie
Bernie
Clever…but wrong. :wink:
The OP did say “~” (approximately) 30kph.
The Aeroheads are only slightly better than the box rim you have, and might save a minute max. Get the FP60s; 4-5min. is about right.
I disagree. The “~” (approximate sign) doesn’t necessarily mean anything except approximate. The fact that the OP used the word “average” indicates that over a given distance he was going to ride approximately 30kph.
The question he should have asked is “Approximately what kind of a time savings would I get over an IM bike distance with these 2 wheelsets?” or “Approximately what kind of a time savings would I get over an IM bike distance if I can hold 200 watts the whole way?” Alternatively he could have asked, “Approximately how much easier will an IM bike be with one wheel set over another given that I can average ~ 30kph?”
He is asking how much faster he will go with one or the other, therefore the speed would have to be different with one or the other. You can’t ask for a speed distance between 2 variables and then set speed as a constant. The answer will always be zero.
Bernie
Seems like about 1 minute per hour (or 1.5+percent) is what I have read in a few places. I replaced my “normal” wheels with FP 60s a couple years ago and would agree with that guesstimate. They are definitely faster, but its not like its night & day faster.
“clever girl”
Concur. The problem with wheels like this is that you don’t immediately notice that they’re faster, unless they significantly less. Don’t expect night and day - just trust the data.
