I recently ordered a WB disc cover for my HED Alps 650c. Had WB cut the covers for me. I used all of the mounting holes and screws. I installed screws opposite from each other for even installation (like how you tighten the lugs on you car wheels). I used the shorter set of screws and the disc isn’t “even” all the way around on both sides. I also ran electrical tape all the way around the edge. Should I remove some screws and go with a 4, 2 or no screws configuration?
I Haven’t ridden on it yet, but will the warped cover affect anything?
Also when the chain is on the biggest cog on the cassette. It’s definitely touching the disc. I assume I’m never going to be coasting and in the lowest gear so it shouldn’t really matter right?
Are you saying that you get lumps in your disk or that it isn’t circular. If it is the former, try using the long screws. I got a lumpy disk with short screws then moved to the long screws and it (mostly) fixed itself. I also use electrical tape, but only in small strips to damp out the noise. I figure if you run tape all the way around you probably wouldn’t need screws, but I wouldn’t count on it. Rain or heat might reduce the stickiness of the tape.
My chain also runs against the disk in the big gear, but I also just figured that I wouldn’t coast much in that configuration.
There is a pattern to the holes, you have to keep rotating one side till they all line up. as for the cassette touching you could open the hole up a little bit and it will lay flatter.
I had similar problem with a cane creek wheel, the cover was just not going to fit the wheel no matter what I did.
In a moment of sheer stupidity I tried blowing some hot air from my GF"s hair dryer, to try and mold the drive side cover…and yep…that totally ruined it.
$100, down the drain…
I have a lumpy disc. I’m going on my first ride on it today but afterwards I think I’ll try 4 or 2 screws and tape and switch to the longer screws. Hopefully that will flatten it out.
Not exactly sure what the problem is based on your description, but it could be that you need to loosen the screws. On my 808 cover, I initially tightened the screws as far as they would go. Heavy waviness. Loosened them all up tp the point when they make the edge of the cover just touch the rim. Still some waviness, but wayyy better.
My initial install had the cover a little warped. But then I realized I switched the sides and it was smooth. Also make sure you dont crank down those screws untill all of them are on there.
I bought a Wheelbuilder disc and paid for the custom. It still fit my wheel like garbage and would move around. I could have done the electrical tape thing but after modifying it I put it in the trash and bought a proper disc.
I had a problem with the cover rubbing on the cassette and rear der. when in low gear. Also was a little warped. I called Wheelbuilder and they said the small inner circle of the cover is too small for some hubs and I should cut it a little bigger. They said to remove it and carefully cut a slightly larger circle. I had such a hard time getting it on I just took off the cassette and used a razor knife to make the hole a few mm bigger. Worked great, no more rubbing and nice and smooth.
I just put one on this week, haven’t had it on the road yet but it fits really well. One question, what do you all do with your speed sensor magnet if you have a rear mounted unit/w a cadence sensor as well?
Are you sure about this? I’ve had three different custom wheel covers made by Wheelbuilder and they’ve all had major waviness … both on 650c and 700c wheels. I’ve called them and tried all the tricks they’ve told me. They’ve told me that the waviness has no impact on the aerodynamics of the wheel, but I find that pretty hard to believe. Viewed from close to front-on, those waves look to me like they’d be disturbing a lot of air.
I also just got fed up with it and bought a “real” disc.
Just leave the magnet in place. Your speed sensor should work through the wheel cover without a problem. The only thing you need to do is make sure the sensor head doesn’t get rubbed by any of the wheel cover waves.
So I had a similar problem (with different wheels). What I needed to make sure I do was that the cover on the non drive side sat flush against the spoke. The hole for the hub was “slightly” smaller then the hub itself, so it just simply floated on top. Once I pressed pretty firmly (or a file was recommended) I was able to seat the cover on the non drive side of the hub. After I did that everything fit together pretty well.
One trick that worked for me was that I barely attached the screws the first time around. I then taped the cover down and then gradually pressed the screws together. There was only one small warp at the valve opening, but other then that it was great.
The most common issue we see related to disc cover warpage is caused by the center hole touching the hub. If the outer edges of the cover do not sit flat against the rim due to contact with the hub you can have major warpage issues. The cover should drop on the rim and fit as flat as if you dropped it on a counter top. The solution is relatively straight forward, open up the center hole a bit to allow the hub to completely clear the cover. This can be done with a light file if the hole needs a slight modification, or with a razor blade if the hole needs to be opened up a bit larger.
The center hole must completely clear the freehub mechanism on the drive side. Some freehub bodies are slightly larger than others and may require the center hole to be slightly enlarged to allow the cover to seat as far away from the cassette as possible. The center hole is trimmed to a standard 40mm diameter, which fits most hubs pretty well, however there are a few designs that will require a slight modification to the hole diameter.
If you have troubles with disc cover fit please feel free to call me at 626-442-4444. We want you to be satisfied with your cover purchase. If we can’t get your covers to fit properly we will gladly take them back with no hassle.
