Wheel "Wiggle"
To be clear, I’m no bike maintenance expert…not even close.
I noticed an odd sound as I moved my bike (Kalibur) around after my last ride. After a little inspection, I realized it was coming from the front wheel (Pro-Lite Como). There seemed to be a small bit of play (wiggle) in the wheel (hence the funny sound) so I checked how it was seated in the dropout and it was solid. I took the wheel off and it seems like the wiggle is possibly coming from the hub. I have trained and raced on these wheels for 1 season.
What could the issue be?
I’m a bit bummed because I bought the wheel set with the understanding that they were solid, durable training wheels and I have a ton of miles to go before CDA.
Thoughts?
Reply to: I’m a bit bummed because I bought the wheel set with the understanding that they were solid, durable training wheels
I also have a Kalibur with Pro-Lite Como training wheels. I love the bike but I’m not so sure about the wheels. No problems but I will be watching your thread for opinions on the wheels.
Good luck and have a Happy New Year.
sounds like the bearing preload needs adjusting, the lock nuts can slip on rare occasion, its a very fine line between too loose and too tight.
however a competent wrench should be able to correct it in a couple of minutes.
From the product page, it says they use cup and cone ball bearings, not sealed bearings. They need to be tightened every now and then, just a normal part of wheel maintenance. Nothing inferior about the wheelset. If you can, let the mechanic show you how to adjust the bearings when he does it. Pick up a couple cone wrenches, and you’ll be able to do it yourself. It’s very simple.
While you’re doing the above, you might have the mechanic remove, clean and re-grease the bearings. (If you can get him to show you how, this is and easy DIY, too.) Some of that play could merely be the result of the grease getting old and cruddy. I have Speedplay pedals and they develop play when it’s time to re-lube them. But once they’re lubed, they’re solid for another full season.
BTW: How many miles do you have on the wheels?
Longboarder, About 1,000 mi. on the wheels.
Everyone else, Thanks for the advice. I’m all over it.
Your bearings shouldn’t need an overhaul after only 1,000 miles. It’s probably just a simple adjustment with the cone wrenches.
Bibi3: I’m not sure how many miles I have but I’m sure it’s at least 2k. I will be checking my wheels.
Dont have a mechanic show you how to tighten your cones - have one tighten them and walk away. If you want to learn, spend a few hours and learn to set your bearings.
dead right,
I took me ages to learn to adjust my first hub, lots of trial and error.
after that though, it became easy as I developed a feel for the task.
as I mentioned its a very fine line between too loose and too tight, btu an easily found point once you have the knack.
