depending on whether you are looking for clinchers or tubies - that is your first question as the stingers are tubular only (but you could always look at a jet 90/60 combo in that case)
Weight:
Stinger 90 rear - 938g and 60 front - 612 for a total of 1550
Hed 3c front/rear (tubie) 670 and 830g for a total of 1500
= Hed 3 c slightly lighter
I have cut and paste the drag details from the Hed site below for your reference
I have had MANY discussions with many triathletes, cyclists, store owners and some of the wheel manufacturers themselves
I have ridden Zipp 404,606,808 and I have ridden Hed3 Clinchers, Hed3 Carbon, Stinger 90’s Jet60/90
the only wheel I have not used from either manufacturer is their discs.
I am also not an expert in aerodynamics - actually - far from it - I am an average MOP triathlete
Without making this a Zipp vs Hed post - I choose Hed wheels over Zipp - so given that - and back to your original question - Hed 3 or Stiner 60/90…
I am a 200lb clydesdale so handling is not a big issue for me - except in very windy conditions.
My own personal experience - I cannot tell the difference between the Stingers and Hed3c’s in terms of speed and/or handling.
I do respect the advice and input of the guys at Hed - who will tell you and back it up with data - that the Hed3 is the most aerodynamic wheelset in everyday conditions - ie - not in a windtunnel with controled wind speed and direction.
I race IM distance so the gains to be had from an aero set of wheels are greater -given the length of time spent on the bike.
My wheelset of choice in the past has been the H3c
I will be investing in a set Hed 3 deeps when they become available - or possibly just a Hed 3 deep rear and run my regular H3 on the front.
Hed3 = Durable, bomb proof wheels - tested and proven by pro cyclists and triathletes for MANY years - they’re relatively light - come in a tubular or clincher version - look cool if that matters for anything - affordable by aerowheel standards today
I have a clincher wheelset - which just happens to be a Jet 60/90 - because I am just still on the fence about clinchers v tubulars - to be honest - I think the Jet 60/90 is incredible value for money and the new C2 rim technology makes it ride SO nicely
If I had to have just one set of wheels…
Hed Jet 90/60 on C2 rims!!!
Now have I really confused you?
Have a look at where the JET 60 and 90 lie in wind drag - vs the Stinger 60 and 90 - surprising huh???
Wind drag:
Hed 3
Wind Drag In grams, measured at:
Density .0023755(slug/ft3) temp 61 f, 19mm tire Wind Angle 0° 5° 10° 15° 20° Hed 3 CR 187 175 189 173 170 28 Spoke low profile 221 229 273 283 292
Stinger 90:
Density .0023755(slug/ft3) temp 61 f, 22mm tire Wind Angle 0° 5° 10° 15° 20° Stinger 90 194 166 113 204 211 28 spoke 221 229 273 283 292
Stinger 60:
Density .0023755(slug/ft3) temp 61 f, 22mm tire Wind Angle 0° 5° 10° 15° 20° Stinger 60 197 179 191 216 218 28 spoke low profile 223 231 275 285 294
Jet 90:
Density .0023755(slug/ft3) temp 61 f, 22mm tire Wind Angle 0° 5° 10° 15° 30° Jet 90 192 163 111 202 209 32 Spoke 221 229 273 283 292
Jet 60:
Density .0023755(slug/ft3) temp 61 f, 22mm tire Wind Angle 0° 5° 10° 15° 20° Jet 60 195 179 189 214 216 28 Spoke low profile 221 229 273 283 292
