What's the difference? (1)
Longtime lurker posting for the first time…
I’m hoping some of you knowledgeable folks will point me in the right direction here.
Here’s the issue:
I’m about 3+ MPH faster on my 1999 cannondale tri bike for any given HR/Perceived Effort than I am on my 2008 Specialized Tarmac SL2. I really want to know why.
Here’s some detail:
The tri bike is 650c with spinergy rev X wheels.
The road bike is 700c with a powertap and very light reynolds MV32C carbon fiber rims - bladed spokes and 32mm of depth.
I’m built pretty heavy/muscular at 220 lbs / 5’11".
I’m in the 280 Watt range for 60 minute power.
My first year or two of cycling, I trained exclusively on the tri bike. For the next 3 years, I split 50/50 road and tri bike training.
The last 16 months have been 98% on the road bike.
Here’s my question:
Does this make any sense?
I would understand if there were a 1MPH difference, but 3+ seems excessive. I want to apply whatever the difference is to achieve better speed on my road bike.
I’ve messed around quite a bit with position, and I ride on the drops with a pretty forward seat position which should be nearly as aero as the tri bike. Are my muscles just “better” at the tri bike?
Could this be the rims despite being 10 years older?
Could this be related to the 650 size vs. the 700?
Or… does everyone have more or less the same experience?
Thanks in advance for your responses!
-Keith
It is NOT the wheels as the Spinergy are not at all aero. What I would look into to is the aero position of the Tri bike and the possible better power you get from that position.
You really are barking up the right tree and others here can answer better than I as to how you get more power (thus speed) from the 650 bike. What ever you do - dont chalk it up to the wheels.
3 isnt that bad really, i get between 2 and 3 from my soloist to my p3, without race wheels. Mostly from the position you sit up higher and if you have a very good position on the tri bike you may be catching a lot more wind on the road bike. you’re also larger, no offense so you will catch more wind on a road bike then someone smaller who may not see the same difference in speed.
Second as far as HR is concerned your HR will be higher on the road bike since you are sitting up you blood has to be pushed harder to get back to you heart. When you back is flat on a tri bike it makes that process easier. Enough to be noticable on my HR monitor at least.
Hopefully that helps, a persons body is hte most unaero thing on the bike so i would worry abotu that not the two bikes, i doubt they are causing the difference
How exactly are you measuring this speed?
I don’t believe the difference should be 3 mph. I don’t have a tri bike yet, but if the difference is 3 mph I will be very close to breaking IM bike course records if I buy one.
This has been true for several years: riding solo, over the same courses, I average 3 (and often more) MPH faster, measured by both my bike computer and total time.
For example, last night I rode the tri bike on a 10 mile flat loop 4 times, and averaged 21.5 MPH over the 40 miles on the bike computer - total time was 1:53. HR average was 140ish. (no power on the tri bike) wind was about normal. I should have been slower last night as I did hills the night before and was still a little fatigued.
The exact same course on the road bike, I am never able to do any faster than 19 MPH unless I’m just doing one lap, and I’ll be at 155bpm to do it. I don’t know if I could average better than 20mph (30 minutes) no matter how hard I go. If I go at a normal pace for 30-50 miles, I average somewhere in the neighborhood of 17-18 mph.
I think if I wanted to I could TT the course at 25-26 MPH on the tri bike for one lap.
This same ratio holds true on any of the courses I typically use, regardless of wind, fatigue, etc.
Thanks again for the responses.
-Keith
No, no…HOW are you measuring speed? Sounds like two different bike computers, one of which needs to be set up to properly record speed with 650 wheels. Have you done this?
Dave Luscan
www.endorphinfitness.com
can you post a pic of the cannondale?
Thanks!
its makes no sense, at least to me.
but i’m fairly dumb about this stuff.
basically, just by using a different bike, you would chop off around 9 minuites over a 40k TT, assuming 20 MPH to 23 MPH.
you would need to increase your power by about 50% on the same bike to do that. maybe the aero benefits of the bike decrease that requirement, but not too much…
check your bike computer.
Sounds like your bike computer is using the wrong values for you wheel size! I noticed a fair differnce when I forgot to adjust my Cateye when i changed tires from 23c to 18c. So a wrong wheel size would huge!
-Keith
Based on your stats and the flat course, thats 231 watts. of course, no wind, but for comparision sake, doesnt much matter…
25 MPH would get you done in 1:36 on the same course, same day, same conditions and require around 354 watts, 53% increase.
26 MPH would get you done in 1:32:19, and require 392 watts, 69% increase off your capable 231, and a still solid 10% increase off your “25-26” prediction range, “if you really tried hard.” funny, considering in your OP you state your 60 min power to be 280.
I’m not sure how you record your data, but that process needs to be reviewed.
EDIT: sorry, missed the part where you said, “for one lap.”
thats still 354 watts for 24 minutes or 392 for 23.
All - thanks for your posts so far, particularly about the spinergy wheels not being terribly aero - that’s very helpful. Here’s a photo of the MS4000 (this isn’t mine, but mine is identical) http://inlandinferno.com/2003_PICS/Ms4000.JPG
Cusetri - I appreciate the analysis and I’m sure whatever table you’re looking at is correct insofar as the typical athlete, bike, position, etc. I’m a numbers geek, and your post inspiries me to start looking at that kind of thing and keeping better records, paticularly with respect to wattage (which I’ve just started training with). During previous summers, I’ve been in better shape and weighed less - maybe right now, I’d only be able to do 24 on the tri bike and 20 or 21 on the road bike over 10 miles.
On the tri bike I’m faster than just about everyone I see where I ride. On the road bike, I can’t hang with the faster club guys for more than a couple of minutes before I get dropped. I’m 100% sure that there’s a 3 or more MPH difference (both on computer and total lap time) between my Tri bike and my road bike. To your point, that seems to translate to a sizeable chunk of wattage or a big aero (dis)advantage.
I think by providing too much information, I may have focused the discussion toward wattage, which I didn’t intend to do… I’m a newbie in that area, and my power numbers are somewhat speculative.
My goal by posting is to figure out if this is normal and I need to quit my complaining, or if there’s some way to get my road performance closer to the tri bike.
Seems to me it would be one or a combination of the following: wheels, size of the bike, aero position, or muscle efficiency in a specific position.
Ideally, I want to wave a magic wand and poof change my aero bars & shifters to normal bars. And poof change my harsh old aluminum tri bike into my smooth new specalized CF bike. :slight_smile:
Maybe I just need to walk into my LBS with both of my bikes and pay a “professional fit” guy to help me figure it out. I figured this might be a better place to start and other folks might have the same experience.
-Keith
KPA - im about 2mph faster on my tri bike vs my road bike
both bikes are cervelo aluminum, same wheels and tires
so your results seem pretty normal
tri bikes are faster, yay
If we could see a picture of you on each bike it would help us to determine how much of that difference we think might be likely to be simply from aero positioning.
Then we could speculate about aero equipment and rolling resistance and the additional difference you might see there.
