I’m sure some will say “just ride your tri bike,” but I don’t see why I wouldn’t see fitness gains using both. I ride an '09 Orbea Orca and an '08 Orbea Ordu.
Here’s the geometry:
Ordu-size 54
seat tube 580
top tube 549
head tube 104
seat angle 76
head angle 73
aerobars-P/D Carbon X 1.5 w/ 100 stem, I was unable to find drop angleinfo
Orca-size 54
seat tube 490
top tube 550
head tube 152
seat angle 73.2
head angle 72.6
110 stem, not sure of the drop angle
So what do I need to do?
Should I have the same saddle on both bikes? I had the Cobb v-flow max in mind…
Well you need to start with a seatpost that corrects about 2.8 degrees then match your other measurements. (Really an '09 Ordu only has a 76 degee seat tube?)
I would have thought that it was at least 78?
To me, the best reason to have two bikes is that they don’t ride the same. Or, I don’t ride them the same way. Road bike–sitting upright, comfortable, sit the saddle on the tailbones. Tri bike–flat back, arms stretched forward, sitting farther forward on the nose of the saddle. When you hit a high volume on the bike you will welcome the difference in how you ride each bike.
On the other hand, I did have my road bike built at 76 degrees and push the seat forward a bit so that the difference in saddle position relative to the bottom bracket is not so extreme. I think the road bike is 4cm behind the bb and the tri bike 3 cm in front. It used to feel really, really weird when I swapped with my old road bike and the seat was like five inches further back than the tri bike position.
Some of this depends on your race distance. If you race long then you probably should ride your Tri bike a proportionally larger amount of time. I prefer short so I can get away with about 30 per day on the tri bike and be fine. I don’t do IM, nor care too, but if I did then I would probably ride my tri bike almost exclusively.
It also depends on your tri bike position. If you ride fairly upright and not very far forward then your road and tri fit won’t be that different. The more aero you are (ie flat back) then the more you will need to ride the tri bike to accustom your neck, shoulders and tender parts to that position.
