Whats new………………. SauconySpring 08
ProGrid Paramount a shoe with initial very limited launch Available to platinum dealers that pre-booked the shoe Sept 1 October 25 to all other dealers. MSRP $165!!!
This is a stability shoe but is targeting the mild overpronator, as this is only mildly medially posted. Features a full length flexion plate as in the Grid Sinister promoting propulsion at toe off. Full length progrid system with 25% more progrid material than the triumph has. Saucony Superlite midsole, upper has comfort-temp inner layer as a temperature regulator. Has a slimmer fit in toe box than oldstyle Saucony fit, more like the current triumph fit.
Triumph 5 msrp stays at $120 10/25/07 release
Is a half ounce lighter than the T4 but to me seems to be a similar shoe. 2 color options for men and women. More heel decoupling allows for various areas of striking the ground and improved rearfoot transition at heel strike. Full length superllite midsole and full length progrid. Midfoot shank is up under the midsole instead of outside, heel fit adjusted to not “poke” into Achilles (some had issue with this in T4) Arch lock now tied into the lacing on the medial side to “pull up” better when shoe is tied.
Trigon Ride color update (I think January) The Trigon Ride becomes the Progrid Ride 5/25/08 finally getting rid of the “Trigon” name….
Sinister color updates 1 in October and 1 in January
Hurricane 10 1/25/08 msrp stays at $130 mens weight 12.1 womens 10.1 has a more streamlined arch lock system. 2 colors with 1 main color offered in widths. Built on the same last as H9, but with a change in upper materials and change of overlays should “feel” brought in a little.
Omni 6 color updates plus the womens becomes SADMERC approved so can be used in Medicare’s diabetic shoe program. Omni 7 coming 5/25/08
Progrid Guide 2/25/08 finally breaking away from the mislabeled “Trigon” name…The new Guide has a slightly smaller medial post than in the Trigon 5 Guide to separate it further from the Omni in support, still mainly targeting the mild OPer. 2 colors for men and women with 1 color available in wides.
Stabil 6 color ups… Stabil 7 coming Sept 08
Type A2 1/25/08 weight reducing it down to essentially a racing flat from it’s previous version being sort of a “tweener” between lightweight performance and racing flat. It is now only 6.9 mens and 5.9 womens. Like the Tangent’s “Lickity Split” it has a “saying” on the shoe…”Kiss this” (how is that for attitude!)
Fastwitch 3 3/25/08 no longer doing both an endurance and light version, is now more like the endurance, is 7.3 oz mens and 6.2 womens
Also now offering kids versions of the Triumph for $55 and also another shoe called the Ignition $45
I think that is it…………
