What's it take to break 1:30
Thanks…wasn’t sure and am too busy to do the math. I did a 1:34 and my pace was 7:13… I think I recall correctly!
I also don’t think that there is any one way to get there. I know an “Old school” type runner that qualified for Boston when the time was 3hrs or whatever it was. His plan was “Run a long run once a week and then do quarter mile repeats, lots of them” Worked for him.
I think “Running smart” is also the key. There appears to be a rhyme and reason to what works and what works for one person doesn’t for another, so you have to be smart and incorporate what works for you…now if I could just find out what works.
~Matt
Get a coach whose taken someone like you before and delivered you to the goal. There are 1 billion unique responses to your question, plus one unhelpful asshole reply from an alleged coach, that you will get on this forum.
Short of that, take a look at www.runnersworld.com/smartcoach
You don’t need a coach to break 1:30. You just need a brain (and the know how to use it).
I’ll echo what someone else said about half-mile repeats and add in hill repeats. If you can, find a good-sized hill (about 1/2 mile in length) and do 4-5 repeats at around 7:00 pace with easy recovery coming back down. Also, work in some tempo sets into your long runs (say repeat 5:00 tempo, 5:00 recovery; or 3x 15:00 tempo, 5:00 recovery). This worked for me in getting my 1/2 mararthon times down from 1:31-1:33 down to 1:28-1:29.
I also agree with Fleck’s suggestion on getting some 5k’s in.
increase your run frequency. Last year I went from a 1:31 half mary PR to a 1:32 half mary ran in a half ironman, which I think is a big improvement considering I ran the 1:32 after the swim and the bike. I did so running 6-7 days a week, with long runs getting into the 18 mile range. Run hilly routes.
GUTS
i’ll second that. i ran a 1:29.12 and it was agony from the first kay. learn to deal with the pain and HTFU. all the training in the world won’t help you if you can’t accept the fact it won’t be easy…if it is, you didn’t go fast enough.
If you can run 1:41 with “a little bit of training” you may already be there. These long distance events really require doing the miles with no short-cuts. The key is number of miles, more than the training pace.
There is a lot to say about this and a lot of different ways to get there. I also ran a 1:40 half last year and am shooting for much faster one this year. I’ve found a training program that looks really good to me and am really excited about trying it… check it out:
http://www.time-to-run.com/training/10k/sub35.htm
I’m just waiting for my last tri of the season, then I’m going to do a couple cycles and see where it takes me.
I have been dealing with running related injuries for the past couple years so my running has been reduced to twice a week. I have managed to keep my 1/2M times below 1:30 with the following:
Running: One long run, depending on time of year training wise that will be 10 - 15 miles, I run this at 10 seconds slower than my goal pace. Second run is speed workout, for 1/2M training I find that 1/2 mile repeats at 15-20 seconds faster than goal time is good. I build up to 13 repeats with 1/4 jog between.
To supplement the running I do a lot of biking. The other training I have seen add great benefit is spin classes on the bike. These are a great long (45+min) anaerobic workout that does not beat you up like running hard does. I try to do a least one preferably two a week.
To me the key is not the volume of running, focusing on the speed is.
Good luck, you can do it!.. So your tellin me that if your goal pace was 6:45 than you run 15 miles at 6:55 pace and than when you do speed work out than you run 800’s at 3:15 ?? Thats one of the weirdest training philosophies i have ever heard!
If you can put in 45-50 MPW, you should be fine as long as your long run gets up to about 2 hours and you get some good tempo work in. 800s also help. I did 1:21 a few years back and basically I just did a 2 hr long run, a 45-50 minute tempo run, one track workout of like 6-8 800s and a few easy runs. About a month after that I did a 1:36 and felt like I was jogging.
Now, if I can do a 1:40-1:45 at soma, ill be set!!!
“then get locked in the LSD rut”
That’s easy for even a seasoned runner to do. I’ve got the Marine Corps marathon as my only race this year due to other priorities, and I’ve been training fairly well at about 60-70 miles/week volume for a couple of months now. I realized a couple of weeks ago, though, that most of my running was LSD except for my hills and mile repeats workouts. I’m targeting a 2:50 time and I realized I wasn’t going to get there if I didn’t start doing some hard mid-distance runs. I’ve added a 12-15 mile hard effort for the last couple of weeks and I can already see the difference. This morning’s run was just under 13 miles at 1:25. My cadence problems are correcting themselves, my sensitivity to hard pace is improving, and my body comp is moving to the next level.
For the OP…if you want to run <1:30…you need to start doing some hard 8-10 mile efforts each week. Slogging through 8-10 miles at an 8:00 or 9:00/mile pace isn’t going to cut it. Save the LSD pace for your weekly long run…and even then you’d do well to consider putting in some harder efforts in the long run too.
I noticed that you ran a marathon. If you want to run faster for the 1/2 Marathon, forget about the marathon. As strange as it may seem, focus on the 5K and the 10K. If you do the RIGHT training for these events with a little bit extra volume, you will get your PB for the 1/2 Marathon. The performance value of the 5K and the 10K is very much under-rated by many rec-runners and triathletes.
You sound like Owen Anderson! In fact, I think the title of the article was something along the lines of improving your 10k to improve your half marathon.
Indeed, I have read a lot of Owen’s articles on PPOnline. Great stuff!
Indeed! Now shhhhh…
thanks guys for the ideas.
I think I’m going to focus on dropping my 5k and 10k times to something respectible, and throw in a weekly LSD long run to keep me used to doing longer distance (and because I like running long).
Any thoughts on what kind of 5k or 10k time I should be targeting?
As I said earlier in the thread … sub 20 5k’s and sub 40 10k’s.
thanks
Vortmax,
 There is a lot of great advice on here if taken in the right context.  However, if taken in the wrong context, some of it can be pretty bad.
 I'll give you some basic ideology and then feed you something specific.  In a nutshell, the 95% of the solution is going to come from getting the right amount of training in, not training too hard, being consistent, and getting in some variety.  This spreads across the board from the 5K all the way up to the marathon.
 No matter what the distance is, your number one key component to training is going to be lots and lots of running in zone 2 as often as possible year in and year out.  I have to remind people that even elite steeple chasers will run 100 miles a week in the off season, and they're only training for a 3,000 meter race.  I recently got the chance to look at Steve Scott's training logs and he was running 80 miles a week to train for the mile.  Guess what.  This is even more important when training for a HM.
 Now, keeping that in mind, the guy who ONLY trains in zone 2 will get beat by the guy who devotes 10-20% of his training in the months leading up to his goal race to faster paced training.  This includes *some* hills, *some* sprinting, *some* intervals, and a fair amount of zone 4 running.
 The best thing you can probably do for yourself is to buy Pete Pfitzinger's Road Racing for Serious Runners.  It's very similar to Daniels' Formula, but IMO easier to read and geared more toward mortal men (Jack's book is pretty aggressive).  Go to Amazon and order it online.
For the benefit of the forum I’ve included a sample of one of his plans. This will give you an idea of what a sound training plan will look like:
http://i14.tinypic.com/67rh9uf.jpg
IMO, the few months leading up to this should be spent focusing more on total mileage and less on the otehr stuff.
Good luck. Let me know if you have any questions.
