I usually use orange Gatorade on the bike and for long runs, but only water at the pool. After about an hour in the pool I start to wonder if Gatorade might not be a bad idea, especially early in the morning.
What are you drinking?
if i am just swimming, meaning that is my only cardio workout, i use nuun. i think having some electros in your bottle is good. however, i don’t want the calories or sugar of a gatorade. if i am stacking workouts, i will start with whatever i would have on the bike during the first hour of a long distance tri. in this case g-push g-1 (of course one day i will run out and then where am i?). i think you want the carbs to make the next workout more effective.
How has your experience with Nuun been?
I’ve always used Gatorade because it’s cheap and available, but the idea of a wafer that I can carry might get me hooked.
It doesn’t have any calories? How does it work?
i like nuun. it has a very mild taste (watered down gatorade lemon lime) and good electrolyte mix. i like it precisely because it has no calories, but i get taste and some salts. really easy to take on long rides and the put into water you get on the road. gives you the thirst quench that you need in a portable solution. however, you then have to rely on gels and bars for your calories. which is okay as long as you factor that in when you are packing your food. people race IMs on it even.
i’m also anti-gatorade due to the sugar. that’s all bad if you want my $0.02.
If I remeber correctly Freestyle fills his with vodka for the really cold swims.
I like the HEED, but at a low dilution. I think it all comes down to length - over 1 hour seems like a good time to take a few calories. Most likely you are not trying to loose weight, so I am sure your body will be happy with the given energy. Personally, I’m anti-sugar, but whatever works for you sounds best.
I like to try to eat a bar afterwards too for some protein source, and drink lots of water as I always feel dehydrated after pool workouts.
good luck
Mostly Gatorade when I bring a bottle.
jaretj
I just drink right out of the pool. It saves time.
Half this forum pees in the pool. Just thought you should know.
That’s probably why he likes it. Adds flavor.
I pee in the bottle under water…
Swim bottle?
I never swam far enough for a swim bottle. If I ever felt thirsty I would just get out of the pool and walk over the the water fountain and have a drink.
Fleck
What Fleck said.
