What would be the best valve extenders for a Planet-X Pro Carbon 82/101 Tubular Wheelset?
Tires?
I bet if I put the word “drafting” in the subject-line someone would respond.
Tufo valve extenders come in different lengths and can be stacked/connected to reach desired length. You remove the valve core and re-attach it at the end of the valve extender. Continental has 40mm valve extenders of the same type.
Both can be found at biketiresdirect.com.
I’ve used the Tufo extenders on 90mm carbon wheels and have had no problems.
Or, if you hit “Search” I bet you could have found the answer about 500 times over - and that is just in the past year.
Actually, I did search this forum and Google as well before posting my question. There isn’t much out there for 101mm wheels. When I searched “valve extender Planet-X Pro Carbon 82/101” on this forum this is what I found** ** http://forum.slowtwitch.com/gforum.cgi?do=search_results&search_forum=forum_1&search_type=AND&search_string=valve+extender+Planet-X+Pro+Carbon+82%2F101+&sb=post_time
But thanks for your helpful reply.
So then…presuming you are looking at a quality tire…what does that have to do with the wheel in the real world?
