What Tubular Widths are you running?
I’m getting ready to replace the tubulars on a set of 909’s and a rear Stinger 50 and wanted to see what everyone is running as far as widths. For the 909’s I’m either going with Conti Comps or Vittoria. The guy I bought them from has 19mm on the front and 22mm on the rear. The Stinger 50 had 19mm Tufo S3 Lites front and back. I flatted the rear on my last race of the season so I’m trying to decide if I should just replace it with the same tire or change brands. It was a pretty new tire so I am a little surprised it flatted. I’m doing the CAHIM this year and then mostly Sprints and a couple OLY. I may sell the Stinger’s but I’ll need another rear wheel if the conditions aren’t suited for the disk. I’m looking for suggestions on tire types and size and just curious what you run on your race wheels. Thanks!
I run 21s. I feel it’s a good compromise between speed and handling. Works well in crits and TTs.
i run tufo s3 lites 21mm on my 606’s
22 front & back
Same as TRI3SM: Tufo s3 lite 21mm front and rear
Also got Conti Competition 22mm on the other disc
Honestly, be more aware of tire selection than width. You probably won’t notice a huge difference between a 19 & 21 on a TT bike. The performance difference is minimal as well. As far as I know, rtolling resistance is actually higher on the 19, contrrary to what people commonly think. Are the aerodynamics that much better on the 19? Let’s just say with most people position is the limiting factor in aerodynamics.
As for tire choices, we really like the Tufo S3’s, the Jet Eilte, and Conti Competitions. The Tufo don’t handle quite as well as the Conti’s, but they are MUCH easier to get on and off. During a race this is VERY important. Additionally, durability on the Tufo’s is top notch. For these reasons Tufo is our #1 tire for tubie tri bikes.
We’re playing around with the new Conti GP4000 tubular. Not enough expereince for an opinion yet, though.
I like the zipp tires on my zipp wheels. They only come in 21 and, according to zipp, they have been optimized for use with their tires. I believe they are made by vittoria. joshatzipp has written some interesting stuff about the tire/wheel combo on this forum.
-C
On my tubes:
Conti Competitions 19 front 21 rear
jaretj
Josh said that it is not recommended to run 19’s on Zipp’s. There is a aero hit on them and it has been proven in the wind tunnel.
My personal pick are conti competitions (22) not the 19’s.
Sean
3 years on Veloflex’s - 22 mm on 909’s
I just got some Conti’s off biketiresdirect.com and I’m pretty sure they’re 19mm. I’ve also got some Vittoria 21’s on a different set of wheels. I don’t think that 2mm in either direction is going to make much of a difference for a MOP’er like myself. Getting tubies at half-off however does make a difference :slight_smile:
Luckily for me I don’t have first hand knowledge of this BUT I’ve heard that TUFO’s are easier to take off if you flat during a race.
They all come off hard if glued well
I think I would cut the tire in a race if I had to get it off.
I run whats on sale to. :wink:
dirt
