I’m finally breaking down and doing it…getting my Max VO2 (who cares), Lactate Threshold and HR tested in a lab next week. Doing the test on my bike on a computrainer with gas mask and all.
Other than my finger being used as a pin cushion, what else can I expect from this test?
to be really tired at the end (even with just a 15 min test) …
If you plan on training with the info you get, it will be helpful. In other words, using the HR data to train at a given pace, etc. Remember, a bike VO2 test will yield different numbers from a treadmill (running) test.
I was told to choose the weakest of the two sports (bike/run) for my test. I’d love to run for the test. Plus I was told if I have a power meter (which I do) to choose the bike for the test.
Lots of pain and suffereing, and about 47sec after the end you will think to yourself - “I think I could have gone for longer…”.
Results - baseline for performance, and you can set training zones (assuming the test is done well) for optimal training!
Enjoy!
It’s essentially a day of intervals with ever increasing speed. Kinda weird but I did this test 2x fairly close to each other (both for the run). The second results were much “better”. I attribute that to knowing how to do the test. If you have a fair amount of control over your normal heart rate and relative exertion levels for a particular stresser, you can change the values being tested. Same goes for tests like the Myers Briggs. People who are required to take it on a regular basis can rather easily manipulate the results…so long as they are not actually crazy…like me.
Like others have said, if done properly you will get a great baseline to train from. Also, the bike results would be different from a run test. I have done the bike test twice, a year apart, to help in training. I have never been good at following training plans but have witnessed others use their results to great sucess. make sure you are well rested before doing the test.
So you’re saying you can fake a large/small VO2Max?
For the most part, one can not simply change their VO2 on a whim.
I think about it this way. If I run up a hill every day. It stands to reason that my “ability” to run up that hill will increase. But how do we define “ability”. My progress could be attributed to correct strength training. Perhaps longer swim, bike and run workouts that increase my overall aerobic capacity. Perhaps I’ve lost/gained weight. There are many possibilities. Perhaps I get “better” at running up that hill because I’m use to doing it. Should I take on another hill–even if it’s the same grade, surface, altitude, distance, etc–I may not be able to run that new hill as well as the old one. The same theory can be applied to racing. For some people, they race better when they are very familiar with the course. You can not (that I am aware of anyway) measure or calculate this anomaly. It just exists. I believe that if you are “one” with the stresser that is being tested you are (or at least can be) “better” than a test will show. Yes, you can manipulate the results.
There is absolutely nothing in this world that the mind can not overcome.
Comparing a vo2max test to a myers-briggs seems like a bad analogy though. If we are even going to go there, I’d be comparing a vo2max test to an IQ test.
My finger hurt for several days…you can pincushion 1 and only 1 hurts or you can try and spread it out over multiple fingers.
I don’t think the tests are that useful to guide training - I like real world tests better but its fun to look at the data and see if it corresponds to what you expect…I had fun doing the couple that I’ve done.
VO2 max - if its higher than you expect - then you’re slow for VO2 (and nobody will think the test was valid) and if its low then you have limited potential and it will work against you in your mind…better not to know (or maybe thats just me…) - although I may get mine tested this summer for the fun of it…
The blood draw test is a lactate threshold test. It is my understanding that this test is good at identifying your LT, but less accurate at identifying AeT than the VO2/metabolic test with the mask. With that being said, I believe that these tests are great for identifying training zones. It’s good to have both the running and biking tests done. These zones will likely be quite different depending on where your strengths are. In addition to nailing down the zones, the tests can be used to determine how effective our training is and how well an athlete is responding to various phases of the training plan. A third benefit–perhaps related to the first–is to give an athlete confidence that he is working in the correct zone. With 5+ zones, it’s difficult for a new athlete to recognize the differences between each. I spend a lot of time testing myself so that I can do it without all the gadgetry.
Post: I was told to choose the weakest of the two sports (bike/run) for my test. I’d love to run for the test. Plus I was told if I have a power meter (which I do) to choose the bike for the test.
The correlation between power and your training zone/metabolic state is much stronger than between HR and state. So, if you have to choose one and you’ve got a power meter–the bike data will serve you best. Plus, I think that the bike fitness is so important anyway.
Actually, Paulo’s pretty much right, you can’t fake a low VO2max either, otherwise it wouldn’t be a VO2 “max”. If the tester knows what they are doing they will be able to tell if you faked it. It’s more a case of just telling whether you made it to true “max” VO2 though (I’m sure no one would pay hard earned money to fake it). Which brings up Voitgh’s point about “learning” the test. I agree entirely, having seen it many times. It’s more a problem for the average recreationally active type though, not your average ST’er. The important numbers won’t change too much for those that have spent many hours running and cycling in anger.
