Well, it’s Christmas and, like always, I should have a couple of extra bucks to spend. And I do mean a couple, not like the mega bucks most of the people spend on this forum. So… I have IM AZ and looking to achieve the best aerodynamics for my buck, essentially.
Here’s what I’m considering:
Aero cover from Wheelbuilder - $95
Giro Advantage II - $160 w/ shipping
Used front wheel aero wheel - Probably $200+
I’ll probably only be able to afford two of these, so what would you do? The aero cover is almost a given, but should I get the aero helmet or the front wheel? I currently have a Velmax Circuit up front.
Thoughts? Any good alternatives would be considered, also.
Have your ears removed. That way you’ll have aero advantage on more than just the bike.
That’d be a great idea, but I fear that should my girlfriend and I break up at some point, I’d be resigned to have my hand as my only companion for no girl would ever date me again.
I’m in SoCal too but if it gets real hot (and you never know what race day will be like) I’ll drop the aero helmet for a vented one. Not only do you get hotter but you lose the option of pouring water over your head as they don’t have vents on the top. I’d put this as a pretty big consideration for a long course race in AZ and even if I planned to wear the aero helmet would take a vented one along just in case.
Bike fit, and not to make your “front end lower” or any bogus “aerodynamic” fitting horse-hockey. Before the position is aero, it should be powerful. As in-elegant as that sounds it is 100% true. If your fit is dialed from a comfort and power perspective, you’ll be faster.
Aero helmet. I’ve suspected the difference an aero helmet makes is large but recent MIT wind tunnel tests as summarized in *Bicycling *Magazine suggest the advantage may be greater than we originally thought and roughly comparable to the aerodynamic advantage provided by race wheels at a greatly reduced cost.
I couldn’t agree more with the professional bike fit. An aero position that optimizes power output will give you the most bang for the buck. And by professional fit I’m not talking posting pictures of yourself in a dirty apartment on ST.
“but recent MIT wind tunnel tests as summarized in *Bicycling *Magazine suggest the advantage may be greater than we originally thought and roughly comparable to the aerodynamic advantage provided by race wheels at a greatly reduced cost.”
Tom – I can’t believe you’re repeating this drivel. The MIT folks themselves admitted that the article misquoted them badly.
In importance, I would go for the wheel next, but factoring costs, the helmet would be good. If you’ve got a bladed spoke, your wheels are better than you think. Marketing has a way of making us forget the effect cheap things.
Fitting, aero helmet and make friends with someone who has aero wheels and borrow them. I loaned my Zipp 404 and disc out for Silverman to a friend.
Did you get them back?
Depends a bit on what rear wheel you’ve got now, but I still can’t imagine doing better for the money than a wheelcover. Then I’d get a used aero front-- something like a Jet 60, trispoke, or an Alps. Tape the helmet for now.
I bought in this order: wheel cover for my PT Pro, then used HED Jet 60 front. Next would have been an aero helmet, but I figured I should learn how to swim before I totally geek out with an aero helmet.
I would have bought an aero frame last, but came across a good deal on a used Yaqui frame I couldn’t pass up. That didn’t score too well on the $/aero equation, but quite well on the $/satisfaction equation…
