What To Do When Drafting Going Up A Hill
Did a ‘C Grade’ cycle race yesterday and was drafting pretty close off the guy in front of me. I was trying to get quite close to him as to save as much energy as possible.
The only problem I had and which is was freaking out a little about was when he got out of the saddle and started climbing, his back wheel got really close to mine really fast, it sort of jerked back and because I was following so close, I just about hit his wheel which would have resulted in bad news.
How does drafting up a hill differ between drafting on the flats? How far (give me a distance roughly in cm or whatever) should you draft to get the slipstream but not be dangerous?
“How does drafting up a hill differ between drafting on the flats?”
Go ask Contador how he deals with Kloden on the hills. =)
http://www.livestrong.com/video/3808-draft-cycling/
Does this explain what I’m asking? Maybe I just need to stay a bit further back and be either left or right of the guy, not directly behind them?
It’s no different, you be careful enough, attentive enough and watchful enough that you’re ready for the out of the saddle backwards lurch and prepare for it. It can happen on the flat too when a guy decides to attack.
A back wheel / front wheel touch like this is also generally not too bad and doesn’t generally cause an accident, find a field and a mate and practice those wheel touches - and other touching.
I think Bicycling had a really good article about that last month.
We used to call that getting drop kicked. It’s not that the bike lurches backward, it’s that there is a hesitation from the rider before he stomps on the pedals while you continue to move forward at your same rate. This makes it look like his bike is backing into you. Keep enough distance so that you don’t touch or have room to move and briefly overlap wheels. With climbing it’s not really that you are getting much of a draft, just following the other guy’s tempo unless there is a strong headwind.
normal part of pack riding. In training rides, some guys will call out “up” when they are ready to stand to alert those behind. Others learn to hit the pedals as they stand to prevent this and are much smoother. One of my roadie buddies has a very bad stall when standing (and he is an experienced roadie), but I know him, when he will stand, and draft accordingly. In a racing environment, you just need to be more attentive. A slight bump/touch doesn’t usually bring people down, but if it does, it will be the guy in back doing down, not the guy in front - so keep that in mind!
Not much you can do about the guy in front except watch him - folks will often shift before standing up or their cadence will have dropped alot before they stand.
It’s a good idea to work on your own ability to stand up without sliding back so you won’t get tagged by the guy behind you.
Yes, helps when you know the riders in the pack so you can adjust for bad habits/skills. If done correctly, standing up does not have to ripple through the line behind a rider.
There are two components to the backward lurch.
First, already mentioned, is the interruption of pedaling as the rider changes rhythm.
The other aspect is the forward movement of the rider’s hips as he stands. Even if pedaling power remains smooth, it’s the center of gravity of the bike/rider combo that will move forward at the same speed. If you thrust your hips forward, the rear wheel will move back relative to your C-O-G. For every action, there is an equal and opposite reaction.
Standing should be initiated on the downstroke, concentrating on pedaling through the bottom of the stroke right into the opposite downstroke. Also, think about raising your hips up and smoothly forward rather than suddenly jerking your core forward.
Another skill on the list of skills in becoming a better member of the pack.
If you look at many of the Pro Tour guys being paced on climbs by domestiques, they are usually a bit to one side and pretty close up on the wheel vs. having to sit further back and directly behind.
Even on a steep grade when the pros are doing 12mph drafting is still worth a couple %, which is significant at that level.
Dead on the money about the rider in back (whose front wheel touches) going down, if anyone does.
Rroof and Roubaixman are right about this being normal pack riding and you have to be prepared for it. But, you can ride better than this. The ‘backward lurch’ happens when a rider stands without thinking about where her/his feet are in the pedal cycle. The best place to be is after either of your feet have just passed over the top. As you stand, you’re hitting your downstroke. This eliminates that slight pause that give the appearance of a backward lurch.
hth
I’m not sure if I should be pleased or appalled by your honesty about cheating in your race… wait, I’m certain that I’m appalled now. :slight_smile:
It was probably one of those draft legal cycle races.
X2. Wheel touches are only really an issue with inexperienced cyclists who freak out when it happens. No doubt best to avoid the incidence of wheel touches, but when it happens it is best to remain loose and let the bikes do what they want to do rather than force them apart. The momentary loss of momentum that occurs when standing out of the saddle causes the “backward” appearing motion that you notice. Assume that rider in front is going to jump and you’ll be ready for it.
I totally agree with the idea of practicing wheel touches, elbow bumps, pushes, pats on the back, etc… do it on grass to minimize injury to both you and your bike.
apologies… read thru this too quickly and assumed triathlon bike leg
I’m not sure whether to be amused or appalled by your lack of reading comprehension…
Rik
He recognized this and apologized. It’ll be ok.
Schwinding-another issue is when a rider loses focus. 2 experienced riders I can think of off the top of my head, VandeVelde in the '01 Tour Team Time Trial and Leiphemer in the Tour of California this year crashed as a result of overlapping the wheel in front of them.
Keep your focus in a bike race, and don’t panic.
No doubt. I can’t even imagine the “brain drift” that occurs in those guys over those multi stage, mega tours. Day on day on day of endless pedaling, there must be tons of daydreaming going on, thinking about the moment when they can finally rest, maybe imagining the joy of throwing their bikes off a cliff, vacationing in the Sechelles, or whether they paid the phone bill before the tour started. Or maybe just to look at a pretty girl on the side of the road, or the voice of the team leader in their earpiece telling a joke. Gotta be at least some “micro sleep” occurring, too. Amazing more crashes due to lack of attention don’t occur.
