I just put in my measurements on competitivecyclist size guide which came out with a tt of 55 and st(c-c) of 55-56 or st (c-t) of 56-58. My inseam is 85cm, torso 68cm, and height of 73cm.
I rode this past year on a cannondale slice 56 but had the seat post maxed out and had a 40 degree stem b/c my flexibility is poor.
I think I need a seat tube of 56 and top tube of 55. This seems to be an awkward size. I am new to the sport and expect my flexibility to get better. Do I size up to a 58 or XL? How do I overcome the top tube being too long for me? I know custom is probably the way to go but I don’t want to spend the $$ yet.
Road frames might fit me better??
I have been fitted at least 3 times from 3 different lbs and I’m lacking confidence in their abilities and I don’t want to shell out anymore dough for a fitting.
A good place to start for a road frame is with the Lemond formula of inseam x .67 which in your case would be 85 x .67 = 57cm. This is measured C-T. For C-C use .65.
There are weaknesses in the formula and not all bike manufacturers measure their frames the same way, but it’s a ballpark. Read over this site as it might give some insite.
I am in a similar boat (long legs, short torso). I rode a 63cm Giant last year and always felt that I was reaching. I bought a 61cm CX bike for the winter (and a MTB seat post for the length) and absolutely love it.
Without getting into specific measurements, I think the keys are:
Are you able to sit with a neutral spine (i.e. back is flat, not rounded reaching for the bars)?
Are you able to sit with your scapula retracted, i.e. shoulders aren’t hunching forward reaching for the bars
Is their sufficient space between your knees and the bars (esp when standing during a climb)?
If in doubt, I would personally go for the smaller frame with a longer seat-post.
you are remarkably close to my size. FWIW I currently have a 57 QR (really it is closer to a 55). top tube is 55.5 c-c
Here is how I’m currently set up
seat rail to BB 75.0cm
sr to pedal spindle 92.5cm
seat center to armrest center 65.5cm
Seat post to end of stem 67.5
seat (c) to headset center 59cm (on the angle)
Drop is 12.5 cm which is 1.2cm lower than I was originally fitted.
I also ride a zero offset post and I think tat bike is a 75 deg SA (I really have no idea)
i coudl ride one sze up to eliminate some spacers, but this fits really nice. If you have limited flexability and don’t want to ride as steep as me (VSTA is about 81 deg) I woudl go with the next size up to a 57cm with a 56.5 TT
