I currently use White lightning, and I find that it leaves this dark gray colored stuff between the links. I know that that crap is just old wax mixed with dirt. Because of this crap, I wanna get away from using White Lightning. Is there some other chain lube out there that does not leave this crap on the chain…?
I use Tri-Flow (sp?). It seems to work well, but it get’s dirty very quickly. I used to have a tough time keeping the chain clean, but I’ve now figured out the trick. Those chain cleaner contraptions don’t work. Get a chain with a removable link, like a Sachs, SRAM, or Connex. Take the chain off, and put it in an old gallon milk jug with some degreaser. Let it soak (ideally over night). Shake the jug around a little, rinse with hot water several times, then re-install the chain and re-lube. The chain comes out squeaky clean. This was the only way I could get the chain clean with Tri-Flow.
I’ve used White Lightning, and liked it well enough. I had the same complaint when it came to cleaning the chain, however. I’ve used several other lubes, but have found that the two I like best are Pro Link (which I use pretty much exclusively now), and Boeshield T-9, which I still use to lube everything but the chain. The Boeshield is a great chain lube, and I didn’t find it held on to the gunk as much as the White Lightning, but I’m just really impressed with the Pro Link.
Chains should be oiled, not waxed. If you want to wax something…try your legs Wax will do just as you stated…attract all sorts of stuff on the outside of the chain.
I agree that you should remove the chain to clean it, and stay away from those “strap-on” contraptions.
After every ride or so I re-oil the chain…link-by-link…one drop per link. Cycle the chain through the grears, and then wipe the chain down throughly. The oil only needs to be on the bushings, which you can’t see anyway. Everything else will attracted dirt and grim. Frequently I remove the cogs, rings and chain and soak them in degreaser to give them a good cleaning.
Finish Line Teflon Dry Lube. Seems to stay cleaner, longer for me. I do one drop per link about every third ride and wipe excess thoroughly. Degrease with one of those chain cleaning contraptions (I use Park Tool) about every 5th ride.
I use Pedros Ice Wax. If you don’t like wax, Pedros makes a lot of other fine products, but I prefer wax over oil for cleanliness (strange how some people prefer oil for the same reason!).
In a pinch, you can always use transmission fluid like my old bike shop did.
If you aren’t riding in the nastiest possible conditions, use real wax. It doesn’t attract anything to your chain, it is in fact the lightest lube you can use. It may last 500-600 miles, depending on the weather. You totally strip your chain of any other lube by dipping it in degreaser and bruching it for a while, while you are melting the wax. Then put the chain in the melted wax for a couple of minutes. Don’t let the was get too thin or the lube will be thin also. Hang to dry, then put it on and enjoy…nothing is better.
Where do I get it…I’m in NC. Also, would you entertain a private or public question on Zipp wheel hub maintenence (I posted this last week w/ no response and now have more Qs).
Well, i see that you guys seem to rave about the ProGold. Thanks for the recommendation. I’ve also heard about the Dumonde. Anybody have any experience with this stuff…?
I use White Lightning or Race Day. You’ll find that the oil based lubricants attract far more crap to your chain. I was a Tri-Flow user for years, but spent countless hours cleaning that stuff. I do cleaning a lot less often now.
