i have this:
but am looking for a clothing line that offers good reflection…
thanks for any recos!
i have this:
I think that if you have a good vest, you don’t need a lot of reflective clothing. I do all my runs in the pre-dawn dark, and I run with a reflective vest, a reflective Road ID strap, two reflective straps around my ankles and one around my right elbow. I had one lady pull over in her car and thank me for being so visible. If it is snowy, foggy or hunting season, I might wear a head lamp, but to be seen and not to see.
I wear a lot of different outer layers, depending on the weather, so I accessorize. I’ve looked at those illuminite (sp) jackets and am not sure they add much if you are already lit up with reflective gear.
The key thing is to stay alert, because no matter how much reflective gear you wear the idiot with a coffee in one hand and is adjusting his radio in the other and whose window is fogged up or covered with frost because he is too lazy to scrape it won’t see you, so always be ready to take evasive action.
Victor
I have a pair of illuminite gloves - I’m thinking of buying a jacket and hat.
Here is a review with pic of 3 reflective tops, The Illuminite is not very impressive.
From The above Consumer Report Review:
CAUGHT IN THE HEADLIGHTS As these photos show, Amphipod and Nathan Tri Color vests (left and second from left, respectively) are visible from a greater distance than the IllumiNITE jacket or no reflective gear at all.
From 220 Ft From 50 ft
I have learned from researching reflective gear for biking, that lights are far more effective. The problem with reflective items (as discussed in that Consumer Reports Link) is that you need to be at the right distance and angle for them to work. Looks your harness is good because it wraps you in reflective strips. Another downside to reflective stuff is that it needs to stay clean to be effective–if the little reflective pieces are covered in dust or dirt the ability to reflect the light is diminished.
So, in addition to my reflective stuff I try to use solid or blinking red lights. Sometimes I’ll clip one of those little bike lights to the back of my running cap, or run with a lighted arm band. Very dorky, but my I’m worth it. Right?
Also they rely on the lights of the car trying to run you down actually being on.
Sequins.
I’ve got Specialized Armadillo All Conditions Reflective tires on my commuter.
