What is with Desoto?
All the better to demoralize the folks you pass.
I loved the low-cut Desoto shorts 20 years ago, but my body has “evolved” since then.
Conversely I still have one of the (later) 2 piece short and zipped vests that was cut to be long enough to overlap so that there was no strip to get sunburn from the gap between short and top when cycling or give spectators indigestion you were on the run. I’ve lost a bit since I got it so I’ve the reverse, the top now stretches down to almost be a minidress if I was so inclined. That however is a different thread…
Emilio
I’m looking to buy a suit, probably the Forza Flisuit. Looking at the sizing, it seems a Large is the right fit?
I’m 5’10 and ~185-190.
I ask because in Castelli I’m an XL, but I know sizings are different across brands.
Thanks!
Hey AdMatt, So far you are between a Large and XL.
We take great pride in making sure our customers are fitted into the correct size. To do so, it would be most helpful if you would provide us with the following information:
•	GENDER / IDENTITY
•	AGE:  We request this as some people prefer less compressive fit as they get older.
•	HEIGHT
•	WEIGHT (accuracy helps us provide a more accurate size)
•	CHEST (measured as the largest part of circumference right over the pectoral muscle)
•	WAIST (circumference measured at the belly-button line - this is NOT the same as your pant waist size)
•	HIPS (circumference measured at the widest point, NOT at your hips where your belt may go. Typically this will measure just a few inches below your hip bones and around the largest part of the glutes)
If you do not have a tape measure use a belt, or your smartphone power cord, along with a ruler or a house tape measure.
